1978 - 1996 Big Bronco
defroster issue
Old Nov 18, 2006 | 02:39 PM
nowbiteme's Avatar
nowbiteme
defroster issue
89 xlt, 5.0.. didnt use the a/c all year, today was the first "cool" day, and when i turned on the defroster, i heard a little "squeal" noise and then the entire cab filled with "smoke", not "burning smoke", more like fog.. shut off and on, same result, let it run for a couple minutes and the fog never stopped. Plus it never blew hot, just cool..
Thanks in advance..
Old Nov 18, 2006 | 06:12 PM
plowhand's Avatar
plowhand
Playing in the Dirt
The squeal was probably your blower motor, from sitting all year and not running. The "smoke/fog" was probably from a leak in your heater core. It blowing cool could be from the leak in the heater core and/or a stopped up heater core or the fresh air door not closing off. I would pull the air plenum cover (under dash) and look at and/or replace the heater core and check the operation of all of the air diverter doors.
Old Nov 18, 2006 | 09:15 PM
surewhynot's Avatar
surewhynot
I had leaves and debris get in my heater box once and started a little fire in there from the resistor, but if it isn't like burning smoke it's probably not the problem you are having.
Old Nov 25, 2006 | 04:48 PM
nowbiteme's Avatar
nowbiteme
actually the squeal is coming from the A/C compressor, when it kicks in it squeals, when it shuts off it doesnt. Does this mean the clutch is going bad??
Old Nov 26, 2006 | 10:58 AM
helirich's Avatar
helirich
That is a possibility. It also sounds like you valve on your heater water line is not opening. I would unplug the compresser and see if you still have the fog. Mine makes the fog everytime I turn the air on when its raining. But not when the heat is on.
