Engine mount question
Old Jun 23, 2002 | 09:19 PM
dj9124's Avatar
dj9124
I just recently bought a 56 f100 that had a 460 big block in it but it was removed, it had the tubular frame that was welded in and the eng mount pads bolted through a single hole on the frame on each side of the engine, I have seen these crossmembers in many of the parts suppliers catalogs, my question is will I have to put a different tubular crossmember for it to accept a 302? Since the big block was wider than my 302 I do not know if a conversion is possible or not to fit a 302 in its place without changing the crossmember that has already been installed, any help would be appreciated, thanks.
Dave
Old Jun 24, 2002 | 02:46 PM
darkhorse54's Avatar
darkhorse54
You will have to remove the crossmember and use one for a 302 they cost about $65.00.
Old Jun 24, 2002 | 06:37 PM
dj9124's Avatar
dj9124
Thanks Bob A, thats kind of what I figured but I wanted to check.
Dave
Old Jun 24, 2002 | 09:39 PM
19F10059's Avatar
19F10059
Rellim51
18
Feb 26, 2011 11:36 AM
havi
19
Feb 13, 2011 08:52 PM
snoopypup
Jan 4, 2007 11:04 PM
