starter ????
Old Nov 17, 2006 | 10:49 PM
nofate21's Avatar
nofate21
starter ????
i have 92 explorer auto.. over last months it would click, and slighty turn, with sparks , then after several attempts start, know it will not start at all. i have full power of light and radio and horn, windows even after trying several starts, so i dont think its battery. i hear fuel pump turn on then a large audible click ... i sthe problem the starter, solenoid, starter relay or something else and how can i tell/differeniate/test between each thanks for any help
Old Nov 18, 2006 | 07:50 AM
Coastiejoe's Avatar
Coastiejoe
Make sure your connections are very good. Ford starters require an above average connection as compared to other vehicle types.
If it is connected well, then your starter is probably defective...
Old Nov 18, 2006 | 04:38 PM
marragtop's Avatar
marragtop
Run a jumper (carefully) from the hot side of the solenoid to the starter. If the starter works, consider replacing the solenoid.
