1978 - 1996 Big Bronco
racing bronco
Old Nov 17, 2006 | 06:48 PM
bobstrat's Avatar
bobstrat
racing bronco
first off id like to say hi to all you guys. youve got another newb in your midst.
my 1990 bronco xlt with a 5.0 and e4od will not idle down. intake manifold vacuum test did not indicate a leak. ive vacuum tested every vacuum line and found nothing leaking. codes pointed to tps and iac both of which i replaced. i also replaced the throttle body to intake manifold gasket. plugs wires cap and rotor. nothing has helped.
in park it idles at either 1500 or 2100 rpm. put it in drive it will idle 900-1000 rpm. in reverse it idles around 850-900 rpm. what in the world is going on ?
Old Nov 17, 2006 | 07:46 PM
masseysbronco's Avatar
masseysbronco
Question
You do know that when you replace the TPS you have to adjust it so that at closed throttle its between .6 to .9 volts right?
Old Nov 17, 2006 | 08:18 PM
bobstrat's Avatar
bobstrat
yes. im going to double check that tomorrow. i just rigged up a patch cord with tps plugs from another bronco to make it little easier to hook up the voltmeter. but when i closed the hood today it was reading .93
the thing that puzzles me is the different idle between park/drive/reverse. wouldnt the tps affect the idle regardless of gear ?
Old Nov 19, 2006 | 09:06 PM
bobstrat's Avatar
bobstrat
well while messing with it today i put a small piece of cardboard over the throttle body openings with the engine running. the idle didnt change but maybe two hundred rpm. then as curiousity got me i pulled off a vacuum line from the tree tohook up a vacuum gauge and the revs went up alot. put the gauge on it slowed back down.
i am now inclined to think my intake manifold is leaking air. with the openings covered shouldnt the truck have bogged down ? it seems to get plenty of air without the aid of the throttle body.
so im going to dig into the intake tomorrow. if anybody sees a flaw in my logic by all means let me know.
Old Nov 19, 2006 | 09:20 PM
alxsnmr's Avatar
alxsnmr
Remember to check the many feet of vacuum lines running to the engine. You should also check the canister purge valve just off the throttle body to make sure it isn't leaking past the valve with it unplugged from the harness.
Old Nov 24, 2006 | 08:22 PM
bobstrat's Avatar
bobstrat
Thumbs up
well guys just came home with the bronco. first time shes been here in two months. turns out the plenum gasket was shot. replaced that and now shes purring like a kitten. now onto the rear window motor.
thanks to you guys who responded.
Old Nov 24, 2006 | 08:36 PM
alxsnmr's Avatar
alxsnmr
looks like I got your PM a little too late. Glad to hear it is working great, never can tell what the vacuum leak is until you start digging into it.
Panama1
1997 - 2003 F150
Jan 5, 2017 10:46 PM
PapaBearYuma
16
Nov 13, 2016 08:18 PM
wlprice
Mar 23, 2016 09:20 PM
connerjanning
3.0L V6
Nov 1, 2013 09:13 PM
HEpTJJ
Sep 11, 2013 10:58 PM
