Window Switch Lighting
Old Nov 17, 2006 | 03:31 PM
pozman's Avatar
pozman
1) I have a 2004EB on the drivers door all switches light up except the window lockout. Should it?
2) On the passenger front door only the door unlock switch lights and not the window switch.
3) On the rear doors the window switches do not light. Should they?
Thanks in advance
Old Nov 18, 2006 | 12:31 AM
afreemanmd's Avatar
afreemanmd
I have a 2000 Limited, and i dont think my window lockout lights up. I don't believe there it is supposed to, but Im not 100% sure. If its supposed to, then I need to fix that too. all the other switches should light up, but I have no idea how to go about fixing them. sorry.
Isaac
Old Nov 18, 2006 | 11:43 PM
RACERX7775's Avatar
RACERX7775
there is really only 1 way to fix the unlighted switches.....replace the switches. and no, the window lock switch should not light. on mine, its a blue wire on the switch. check it for power first. if no power, then you have another problem. if you have power at the blue wire, then its the switch..
Old Nov 19, 2006 | 12:33 AM
PatsPOS's Avatar
PatsPOS
pozman...sounds like you have the window lock switch in the "lock" position. The light switches for the other three doors are only illuminated when the switch is unlocked. Wait until dark and flip the switch back and forth...you'll see what I mean.
I thought it was pretty cool...but then again, I'm easily amused.
Pat
Old Nov 20, 2006 | 10:05 AM
pozman's Avatar
pozman
Thanks much
Yes it was the window lockout switch being on. Thanks for the input all. Being a newbie owner I guess theres still things to figuer out with this rig.
Old Nov 20, 2006 | 11:09 PM
RACERX7775's Avatar
RACERX7775
Unhappy window switches do stay lit
oh, the thing with the window switches only on when the switch is unlocked, not true at all. i think that there is something wrong with yours if it does that. but then again, mine is an 01. maybe newer ones are different. but i dont think so...
Old Nov 20, 2006 | 11:33 PM
mfwhite22's Avatar
mfwhite22
I have an '04 EB and the lights on the window switches do turn off when they are locked out. Tried it today, never thought about that before but appearently some Ford engineer did.
Old Nov 20, 2006 | 11:35 PM
RACERX7775's Avatar
RACERX7775
hmmmm, see, i learned my 1 fact for the day.. and its only 12:36 a.m. i guess i can sleep till tomorrow now..
Old Jan 11, 2007 | 09:23 PM
garvicmos's Avatar
garvicmos
2004 SCREW 50K mi-Some switches in both my overhead console (operates sunroof) as well as driver door (windows) do not illuninate. Does entire switch need replacing? If so according to RACERX775; Are these switches sold A-La_cart or in set? Is a better aftermarket available? From whom?
Old Jan 12, 2007 | 08:00 AM
Downriver Thunder's Avatar
Downriver Thunder
I have an 00 Limited and when I lock the windows out my lights don't go out either.
Old Jan 12, 2007 | 04:45 PM
WJC's Avatar
WJC
My Window Lights Go Out On All But The Drivers Door When In The Lockout Position, I Think They Started That In The 2004 Model Year. My 2001 Excursion Did Not Have That Feature.
2005 Excursion 4x4 Limited K&n Fipk Gibson Exhaust
twozzie
1983 - 2012 Ranger & B-Series
Jan 24, 2017 04:20 PM
boggin79ford
WTB - Parts & other
Jan 11, 2017 03:25 PM
teamlx88
May 21, 2015 08:30 AM
Russell B
Feb 8, 2005 06:12 PM
Jan 3, 2003 09:58 PM
