Fuel dumping
Old Nov 17, 2006 | 02:41 PM
TWULFF44's Avatar
TWULFF44
Exclamation Fuel dumping
I have a 1986 F250 302 EFI and I am having a problem with my injectors, they are dumping more fuel than they are suppose to. Which in turn makes the motor run rough. Has anyone had this problem before. I had a neighbor who works for ford check out the fuel system and everything checks out. Any ideas where the problem could lie?
Old Nov 17, 2006 | 07:23 PM
LxMan1's Avatar
LxMan1
Map sensor or a cracked vacuum line to it. Check the vacuum signal to the map sensor, with low vacuum, it will run too rich.
Old Nov 18, 2006 | 08:19 AM
TWULFF44's Avatar
TWULFF44
I just actually changed the map sensor and it is running a little better, so would a cracked vacuum line going to it cause that?
Old Nov 20, 2006 | 03:39 PM
LxMan1's Avatar
LxMan1
It the vacuum signal is low to it, it will make it run rich, yes.
5fords&Counting
Feb 19, 2013 10:14 PM
childsupportwin
Jan 17, 2011 08:22 PM
johns4dor
Sep 19, 2008 11:03 PM
fixin737s
May 6, 2007 08:36 AM
shaftmountrocker
Feb 28, 2005 03:47 PM
