Glow plug issues
Old Nov 17, 2006 | 06:51 AM
do the evolution's Avatar
do the evolution
Glow plug issues
hey all, my 2000 f250 7.3 having a hard time starting when its not even cold out. does anyone know how to test the glow plugs? i will check if there is a error code. i have changed the glow plug relay and checked the connections, all look good. is it a big job to change the glow plugs? something i can do myself?
wondering if anyone has had same issues and any suggestions.
thanx
Old Nov 17, 2006 | 09:01 AM
nodakford's Avatar
nodakford
To test the glow plugs, all you have to do is disconnect to connector at the valve cover and ohm the 4 largest pins. You are looking for 2 ohms or less. It is not that hard of a job to change them. A thin 10mm deep well socket works greats. I bought mine at AutoZone for around $9 apiece, Motorcraft ZD11. Do not use Autolite glowplugs.
Old Nov 17, 2006 | 01:33 PM
Uzumati's Avatar
Uzumati
A little more detail when you ohm those connector out go between the pins in the plug and use the block for a ground.
Here is the connector {G G I I C I I G G}
G=Glowplugs
I=Injector +
C=Injector Common Ground
SteveH-CO
Mar 8, 2013 08:58 PM
Sirpecka
Nov 22, 2011 08:44 AM
Attilak1
Mar 5, 2008 07:50 AM
powerglyde1234
Nov 7, 2005 10:31 PM
popkorn
Sep 14, 2003 07:31 PM
