Hydraulic Clutch Conversion.
Old Nov 17, 2006 | 03:04 AM
Johnny0's Avatar
Johnny0
I'm wondering if anyone has ever converted the hydraulic clutch on the ranger over to a mechanical "steel rod" or cable type actuator ? the reason I ask is cause I'm pissed at having to pay fairly high prices for parts that in the past were not necessary "steel rod type actuator" or reasonably priced parts such as the cable type actuator. here's a brief example of costs.
76 F-250 4x4 steel rod clutch actuator, cost $ 0 they don't break.
76 Ford Capri Clutch Cable, cost $ 12.46 U.S.
86 Ranger Clutch Master Cylinder, cost $ 70 U.S $ 109 Cdn.
86 Ranger Clutch Slave Clylinder, cost $ 116 U.S $ 271 Cdn.
Personally I'm not seeing the advantage of hydraulic over old school except it's making someone lots of money !
Old Nov 17, 2006 | 11:00 AM
matt's2.9STX's Avatar
matt's2.9STX
Wonder why no one's biting on this one. I have read a bit on this one and is my own super-gripe with Ford. OTOH, a mech clutch should be hard to use with most Rangers for normal people. Most would blow clutches a ridiculous rate without hydraulics and rough on the trucks. The only real prob is Ford's declining quality with hydraulic seals and persistence of sticking to internal clutch. There was a post in the last day or 2 talking of swapping bell-housings for the 2.8 version which used an external slave cylinder. I know nothing of it's feasibility for newer engines, though- yet. Otherwise, how about a T5 or the like?
Old Nov 17, 2006 | 02:47 PM
BuffmanLT1's Avatar
BuffmanLT1
while it's a completely different platform, I liked my manual/cable clutch on my honda civic I had a couple years ago...
Old Nov 17, 2006 | 02:57 PM
matt's2.9STX
Whoops, I meant internal slave cylinder that Ford will not let go of like most others. Best remedy known is flush the clutch fluid annually with a power-bleeder fitted to its master cylinder.
Old Nov 17, 2006 | 09:41 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Hydraulic clutch never needs adjustment vs antique vehicle mechanical clutch that needs adjustment every 5 - 10K miles. Low/no maintenance is where it's at and vehicles are compared against one another for, amongst many things including annual maintenance cost.
*IC your vehicles are like 21 to 31 years old. Nothing lasts forever and after that many years I'd have to say you got your moneys worth out of it. And that's how I looked at it back in 1980, when I broke the ball stud for a clutch bell crank off in my engine block. Lots of fun when you have 6" of working space and can't just drill it and use an easy out. Yup, the joy of old fashioned clutch setups and their headaches when bad luck strikes.
Old Nov 17, 2006 | 10:26 PM
matt's2.9STX
MM, that bad one I had was an '03 with less than 70K!
Old Nov 17, 2006 | 11:16 PM
Johnny0's Avatar
Johnny0
Yeah actually I no longer own any of the vehicles I mentioned above, those are just examples, if you add up the price of the master and slave it would cost me $ 280.00 before taxes to replace them, I'll stick with the $ 15 or $ 20 bucks it cost for a new cable and the five minutes it takes to adjust it, after initial break in a properly lubed clutch cable never experience's enough stress to stretch all that much, I've heard many horror stories of guys stuck in their driveways spending days trying to bleed their hydraulic clutch set up's, all stressed out and pissed off, meanwhile I'm back on the road cause it only took me 20 minutes to throw a new cable in, and an extra $ 260.00 in my pocket.
Old Nov 18, 2006 | 12:01 AM
RangerPilot's Avatar
RangerPilot
If it's done properly, bleeding the clutch takes but a few minutes.
Old Nov 18, 2006 | 03:30 AM
CowboyBilly9Mile
That busted ball stud took me a long day to extract and when you're only 18 YO you just don't know the tricks like you do 5/10/20 years later. Makes bleeding, using the correct proceedure and applied to quality components, look pretty good.
