column
Old Nov 16, 2006 | 11:27 PM
dayvyd's Avatar
dayvyd
column
recently my shifter on my column on my 77' went out i think..i know its not the trnny. there is so much play in it it wont go in gear at all..i can move it in circles up down anywhere. im think maybe a bushinf or pin or something in the column.. any ideas please help.. this is my daily driver.. my other is a 65' f -100 with a big block 452 that i hate driving everyday
Old Nov 17, 2006 | 12:03 AM
Mil1ion's Avatar
Mil1ion
It appears the shifter cowl needs replacing.
The part is available at many places...I think Ford has it as well.
Old Nov 17, 2006 | 06:16 AM
scottlane's Avatar
scottlane
Shift collar is broken. Very common.
Old Nov 18, 2006 | 11:02 PM
Mil1ion's Avatar
Mil1ion
For those of you that replace this part..the exact paint for Factory restoration available in spray cans is:
1983-1986 Mazda
H1 or Sparkling Black
You can get the coding from these sites.
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
http://autocolorlibrary.com/cgi-bin/...mazda-pg01.jpg
For Canadians.... it is available at C. Tire.
Motomaster Stock # 47-0803-0
Old Nov 24, 2006 | 04:32 PM
dayvyd's Avatar
dayvyd
ok how do i get the part off??? i pulled my sterring wheel off but could get the collar off at all. i took every screw nut bolt whatever off and could not find a way to get it off. i rented the sterring wheel puler and need to return it as soon as possilbe. please any help....
Old Nov 24, 2006 | 08:58 PM
Mil1ion's Avatar
Mil1ion
You have to remove all the inards (shift lever, TS switch ,plate,Hazard light switch and the 3 allen headed screws accessed from the back of the cowl, undo the harness and pull it all off.
Old Nov 24, 2006 | 10:19 PM
dayvyd's Avatar
dayvyd
thanks. i will do this sunday and let you know how it comes out..
Old Nov 24, 2006 | 10:20 PM
dayvyd's Avatar
dayvyd
Old Nov 28, 2006 | 08:05 PM
dayvyd's Avatar
dayvyd
here is what happened. now im just waiting on the part.. i had to take a lock washer off, and 2 nuts at the bottom of the column where it connects to the steering gears...why can i not post a pic??? well anyways the inside of the collar totally broke....
Old Nov 28, 2006 | 09:17 PM
Mil1ion's Avatar
Mil1ion
Sounds about right.
I suggest you *Create a photo gallery* and upload picture into it then tell us they are in there for us to see.
Click the CP hyperlink..... seen in the blue bar just above your first post on the left
