Does everybodys M5OD shift like crap?
Old Nov 18, 2006 | 09:34 PM
Krochus's Avatar
Krochus
You're not going to speed shift the M5OD. It ain't built for that. It's built to move a 5000 pound truck.
I'm not trying to speed shift the thing, I would however like to be able to get the tranny to go into the next gear BEFORE the truck slows down enough to need a downshift.
It's not going to be as smooth as a mustang or other car type tranny. This is a truck transmission, the ZF is even "worse".
I wouldn't even go so far as to call it a truck transmission, It shifts more like a lawnmower. My M5OD makes the AX15 in my Jeep feel like a BMW gearbox, Heck even the toploader in my 66 F100 shifted better with it's completely worn out 30yr old aftermarket shifter.
Old Nov 19, 2006 | 02:44 AM
welder 302's Avatar
welder 302
Mine has 220K on it and is on it's second clutch and is smooth.
Old Nov 19, 2006 | 02:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
If the transmission is not shifting smoothly get it to a reputable transmission shop and have an expert diagnose the problem and the repair. They are no sports car tranny but they do shift smoothly if in good repair.
When I had the pilot bearing replaced in mine the old needle bearing had chewed up the end of the shaft so a straight replacement could not be performed. Normally I would have had to replace the input $haft. Instead the shop smoothed out the shaft with some sandpaper and fitted a plastic pilot bearing used in another vehicle application. Works great and saved a lot of bucks. At the same time I had the clutch & pressure plate replaced, flywheel resurfaced, throwout bearing, and slave cylinder replaced.
Zgarriott1
1978 - 1996 Big Bronco
Feb 26, 2022 02:37 PM
Broncoslocos
Apr 8, 2015 12:20 PM
JustinAK5
Mar 26, 2015 06:55 PM
Mudsport96
Feb 23, 2013 03:53 PM
