carb
Old Jun 27, 2002 | 03:28 PM
58ford's Avatar
58ford
carb
THe holley 1 bbl I have keeps flodding out. I can see through the glass bowl and the float seems to be sticking. Last night it was doing the same thing, so I too the float out and bent the shutoff valve and it seemed to work just fine. This mornin on the way to work same thing. But this afternoon It was filling again. Any suggestions?
Old Jun 28, 2002 | 01:34 PM
boidoth's Avatar
boidoth
carb
Old Jun 28, 2002 | 01:37 PM
bryanknie's Avatar
bryanknie
carb
Buy a rebuild kit, one that contains a float, it may have a leak, usualy it is just the needle valve.
Replace the needle valve and float, make sure you properly adjust the float and you should be ok.
Bryan
Old Jun 28, 2002 | 06:02 PM
darkhorse54's Avatar
darkhorse54
carb
If you're using an electric fuel pump it may be putting out to much pressure, if so then you need to buy a fuel pressure regulator to reduce the pressure, they only cost about $22.00.
Old Jul 1, 2002 | 11:59 PM
58ford's Avatar
58ford
carb
ok I rebulit the carb, but it didn't come with a float. I think the manual fuel pump is putting out too much pressure cuz it still floods out every now and then. Does anyone have a part number for the float so I can see if maybe that is the problem. And I appreciate yall's input. I'm going to get an electric fuel pump,, but what psi should I run? I've heard anywhere from 2-3 or 5-7?
Old Jul 2, 2002 | 01:27 AM
pcmenten's Avatar
pcmenten
carb
Maybe it's not a carb problem. Maybe it's a fuel pump problem. Isn't the fuel pump supposed to bypass at 3 psi or so? Me, I like to fix things so I'd want to take the fuel pump apart and see what's wrong. If it is gummed up, try cleaning it in a caustic solution. Maybe ammonia, or some weak (diluted) drain cleaner. Or you could try dumping a bunch of Marvel Mystery Oil in the gas tank to try to wash it clean. Problem with that idea is that the whole fuel system, the tank, fuel line, pump and carb, might be gummed up so it would take a while to get it all clean. Of course, if it is not the fuel pump, if it is debris in the fuel system that's getting through and clogging the float's inlet needle system, what you'll need is a new fuel filter and to flush the line from the filter to the carb clean.
Best of luck,
Old Jul 2, 2002 | 07:37 AM
Ironwolf21's Avatar
Ironwolf21
carb
I'd first ask if the Needle valve in the kit came with a new valve seat? In other words the little metal holder the valve fits in? It may be worn and flopping around a bit causing it not seat right.
Another cause can be floats not set to the right depth. Normally a certain height is set at the top of play that seats the needle valve. If the float is off a little bit the exact problem you are mentioning happens.
Also I would replace the glass bowl with an aluminum one for safeties sake.
Old Jul 2, 2002 | 10:42 AM
58ford's Avatar
58ford
carb
the kit did have a new needle in it and when I set the float to the correct depth it flooded like hell. I think I'll check out your idea on the dirty fuel system(it sat for 19 yrs). The fuel pump is new so I might also try a regulator. Thanks again yall--jax
Old Jul 4, 2002 | 10:28 PM
julie 54's Avatar
julie 54
carb
a carb kit wont contain a float but you can buy one they come neoprene or brass. the old brass is prone to pinhole leaks. sounds like the problem here. hope this helps!
Old Jul 5, 2002 | 10:20 PM
soso's Avatar
soso
carb
if the float has a hole in it the full hight would not be right,no?
sixshootingexp
Dec 2, 2012 10:30 AM
wicat3
Jun 17, 2012 08:36 AM
Schuyles
Apr 6, 2011 02:17 PM
turboguy
Aug 1, 2005 05:44 PM
mpalamaras
May 27, 2003 05:38 PM
