buying a 4.6 or 5.4 crate short block
Old 11-16-2006, 09:48 AM
poffutt's Avatar
poffutt
poffutt is offline
97 F150 4.6 is blown. rod bearing is shot. What should I do?
1. replace with a 5.4, would the sensor conections and computer work with this?
2. What mods should I add to the 4.6 /or 5.4 to increase the HP?
Old 11-16-2006, 10:53 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
Although a 10 year old truck may not be as bad, these days, you take a big chance that something won't work if you don't replace with EXACTLY the same component. At very least, find somebody who has already successfully done what you propose. Believe me, many things change even when there would seem to be no reason for them to be different.
Old 11-16-2006, 02:16 PM
poffutt's Avatar
poffutt
poffutt is offline
Thank you for the caution MrBSS, that is why I am posting this. Does anybody know the answers to my 2 questions?
Old 11-16-2006, 02:33 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Poffutt, I'm confused. Does your girl friends `97 F-150 have a 4.2L V-6 as stated in your other post or is it a 4.6L V-8?
Whatever the case is on the original engine, you would be best to replace it with the same engine. Changing to a different engine, would be a very involved change as the engine computer, wiring harness and other peripheral accessories are different. This I believe is what MrBSS was trying to point out.
As for mods, the best bang for the bucks would be a supercharger. On the more economical side of things, start with a tuner for the computer.
Good luck!
Old 11-16-2006, 03:20 PM
poffutt's Avatar
poffutt
poffutt is offline
I appreciate what both of you are saying. Thanks! This supercharger...is it kinda like what the Lighting trucks were set up with? If I go with a supercharger..would this require any computer changes? or sensor changes. I think this is a good Idea. Should I get the heads saved 30 thousands or do you think the supercharger is all I need? With a supercharger do you think I should open up the breathing system like headers?
Thanks you guys
Old 11-16-2006, 03:50 PM
KingRanchMan02
Check out the sponsor links at the top of the forum page. Roush Performance and Troyer Performance should have some details on these kits there that would answer these questions for you. These kits will make your truck similar to a Lightning but the Lightning engines do have differences in them to beef them up for the supercharger.
vini888
2009 - 2014 F150
02-05-2011 01:35 PM
Steve Ducker
1997-2006 Expedition & Navigator
16
04-20-2010 11:59 AM
Roguetrader
Modular V8 (4.6L, 5.4L)
10-16-2006 06:53 PM
Shovelhead 93
1997 - 2003 F150
33
08-20-2006 10:33 AM
78fordman
02-19-2004 10:33 AM
Quick Reply: buying a 4.6 or 5.4 crate short block
