Sponsored by: Innova
problems with my stereo :(
Old Nov 16, 2006 | 12:02 AM
Togaduke's Avatar
Togaduke
Unhappy problems with my stereo :(
I have a 2002 F150 4X4 extended cab. I love my truck!!
Anyway, when I bought it years ago, I bought a nice head unit and then replaced the factory speakers. I recently put a 4 channel amp in my truck, around August.
Anyway, a month ago, I started noticing a popping sound. It was fading in and out. Now, it does it after I turn the volume up. I am used to driving with my music so loud that it hurts my ears (i know its bad for you, but I am a rocker!!!), but now I can't turn it up much at all without the extremely loud popping sound. It does it when I listen to CD's and the radio.
Also, when it does this popping, I notice that the headlights will dim each time it pops, and then return to normal.
Anybody have a clue what could be causing this?
Old Nov 18, 2006 | 07:12 PM
MZ89's Avatar
MZ89
You might need to buy a capacitor....however I dont see why it wouldnt do it as soon as you installed the amp.
Old Nov 20, 2006 | 09:10 AM
fordboy_52's Avatar
fordboy_52
sounds to me like a bad ground somewhere in the system. you do not need a cap
Matt
Old Nov 20, 2006 | 01:50 PM
halltrail's Avatar
halltrail
Could you be overdriving the amp....causing clipping? If you are clipping....you could ruin your speakers. Can you try a different amp? I would check your ground too as already mentioned. But I have seen amps not even come on if the ground is bad?
Dave
Old Nov 20, 2006 | 11:39 PM
Erk469's Avatar
Erk469
What you can do is check all of your grounds in your engine compartment..I had the samething going on and all I did was make my own ground wire, well actually 3 of them..I changed the one from the battery to the chassis, the starter and I connected one from the engine to the back firewall..make sure all of you connects are good and clean and have metal to metal contact. I used 2 gauge or better grounding wire.
Old Jan 3, 2007 | 09:52 PM
Gumbyagain's Avatar
Gumbyagain
If your Headlights are dimming chances are you are pulling too much Current through your Amp. If like most "rockers" you strive for Max distortion & have overdriven the Mosfet's in the Amp. I used to repair a lot of Amps & be willing to bet you have a Leaky Mosfet driver stage that will eventually go to cascade failure & fill your cab with smoke as it goes. You did not mention is Amp blowing fuse occasionally & have you oversized it?
Old Mar 6, 2007 | 11:54 AM
Togaduke's Avatar
Togaduke
Unhappy
I seriously have no clue what is causing this.
The grounds are good. I did end up blowing a speaker. Its really frustrating.
I bought this amp and things were great. I spent a good amount of money on the amp and it should handle a lot more than I actually put it through.
Should I check the amp's fuses?
Any help on this would be greatly appreciated. I miss having a good set up in my truck
pacooov
1983 - 2012 Ranger & B-Series
Feb 7, 2017 10:06 AM
Bivika
1997 - 2003 F150
Sep 11, 2016 09:08 PM
jeepfix
Aug 22, 2015 09:18 AM
MasonDixonOutdoorsTM
2004 - 2008 F150
Aug 21, 2014 06:50 PM
alchemist1
Oct 3, 2012 04:49 PM
