Sponsored by: Real Truck
Winter Weight?
Old Nov 15, 2006 | 03:20 PM
fei1's Avatar
fei1
Arrow Winter Weight?
Hey all,
Just curious on some of your ideas for added weight in the bed for the winter season. I need some extra traction and I have experimented with bags of rock salt (bad idea b/c you get rock blocks) and sand bags. I would like to have something that is has a decent weight to it but I don't want it to be messy like my previous experiments were.
Thanks for the help,
Mitch
Old Nov 15, 2006 | 03:34 PM
TwelveAlpha's Avatar
TwelveAlpha
Sandbags work much better if you take a couple of 2x4's and make a square grid that sits with the ends holding onto either side of your wheelwells. I think I'd recommend only if you have a liner. If you dont and it slides around, by winters end you wouldnt have paint left.
How much is up to you. When I had a 150, 400lbs seemed plenty. Now theres always enough tools and what not back there, havent had to add any baggage for a few years.
Also seen using the spare as a slip stopper. Set it in the bed, put the bags on that.
Old Nov 15, 2006 | 03:47 PM
bigskymt's Avatar
bigskymt
This is pricey but looks decent:
http://www.accessconnect.com/shurtra...ion_weight.htm
Old Nov 15, 2006 | 04:29 PM
jake00's Avatar
jake00
I dont think I'd want 50 gallons of water in my bed
Old Nov 15, 2006 | 04:36 PM
PHWLEE's Avatar
PHWLEE
And that 50 gallons will be a solid chunk of ice in the dead of winter too. That could be a torpedo.
Old Nov 15, 2006 | 04:48 PM
twayneb's Avatar
twayneb
I throw in five of the large sidewalk blocks. They weigh between 70 and 80 pounds each. Back end stays tight and improves the ride.
Old Nov 15, 2006 | 05:07 PM
blockmanjohn's Avatar
blockmanjohn
I use solid concrete masonry blocks (between 40 and 80 pounds each depending on size). Water bags, sand bags, and salt bags all turn into solid blocks anyway during the winter, and are usually harder to move around than a regular shaped concrete unit.
Old Nov 15, 2006 | 06:50 PM
duffman77's Avatar
duffman77
I know this may seem obvious to some, but not all know this. Put the weight as far back in the bed as possible (right at the tailgate). I know it is a pain in the *** as far as accessing the bed but that is where the weight has the most effect. If the weight is behind the rear axle it transfers weight from the front axle onto the rear. So if you add 100 lb you might get 105 lbs on the rear axle (where the 5 is lifted off the front). If you put 100 lbs at the center of the wheelbase 50 lbs goto each axle.
Old Nov 15, 2006 | 07:04 PM
akford351's Avatar
akford351
Doesn't it become a pendulum at some point? Wouldn't you want the weight somewhat distributed in front of/behind the axle... just a thought.
Old Nov 15, 2006 | 07:19 PM
duffman77's Avatar
duffman77
Why? Remember these are nose heavy to begin with. The purpose of adding weight is to increase traction at the rear wheel. If you add 100 lb but only get 50 lb increase in traction, you are really only just carring around weight to carry weight because the truck still has to accellerate the full 100 lbs.
Nice truck by the way.
Old Nov 15, 2006 | 08:23 PM
tigerman's Avatar
tigerman
I use a 2 x 6 in grooves in the bed behind the wheel wells across the 6.75 ft bed of my '99 SuperDuty. This holds four 70 lbs bags of sand in place between the 2 x 6 and the tailgate. I load and unload them as needed depending on the snow storm. The bags have additional plastic wrapping to keep them dry. With side mounted tool boxes (additional approx 200 lbs) mounted over the wheels, it's enough weight with good distribution. Loading and unloading is a PIA especially now that I'm 74 yrs old and only weigh 150 lbs myself. But it keeps me lean and mean. In Kansas, we just get snow now-and-then, so unloading makes sense to me. My new Bridgestone A/T Revo tires should really add to the traction.
Old Nov 15, 2006 | 08:45 PM
92f150I6's Avatar
92f150I6
I used to run weight in my old 2Wd f150, but found that it is totally innecessary in my f250 4X4.
Old Nov 15, 2006 | 08:55 PM
CAFordDude's Avatar
CAFordDude
Originally Posted by bigskymt
I was going to suggest this as I know a couple of folks here in SOCAL that have it and really like it. But I thought in the dead of winter when it makes a 50 gallon ice cube it might be a PIA if you had to get it out to use your whole bed.
Us SOCAL folks don't really have to worry bout that freezing thing too much.
Old Nov 16, 2006 | 03:04 AM
bronco521's Avatar
bronco521
i put 8 60lb. sand bags in at the tailgate.now that i got rid of the continentals things should be even better in the snow.
Old Nov 16, 2006 | 03:22 AM
billpool's Avatar
billpool
I use water ballast from http://www.shurtrax.com/full.asp Works great! About 400 lbs worth.
