Sponsored by: Real Truck
Winter Weight?
Old Jan 26, 2007 | 07:05 AM
bc56845's Avatar
bc56845
all you have to do is add a little antifreeze to the bladder so it doesn't freeze
Old Jan 26, 2007 | 08:31 AM
Mr Incredible's Avatar
Mr Incredible
Like Tigerman, I use a board frame across the wheelwells using the supplied grooves in the bedliner. The difference is I use 2x4's.
I'm able to put two sand tubes out at the wheels and maybe up to six more in the box between the wheels. I usually run with two on the outside positions and one in the front of the bed under the toolbox when there's any snow or ice in the ground. When a big snow comes I throw in some more.
When summer comes I stack the tubes up in the shed and dismantle the frame for storage. When a tube is no longer useful I'll put the sand in the garden, flower beds, or yard.
Old Jan 26, 2007 | 08:49 AM
philips's Avatar
philips
For three years now I have used a rubber bed mat and eight 60 pound bags of sand between the wheel wells and the tail gate. The rubber mat keeps the bags from moving around, and the bags are easy to remove and store when needed. Put an extra black tie wrap around the bags as the steel staple does not hold that well. Bags are cheap, between $3 and $4. Philip.
Old Jan 26, 2007 | 10:16 AM
powrstrkn''s Avatar
powrstrkn'
I use 1000lbs of IH suitcase weights. They're meant to be front end weights for farm tractors, so i steal them for the winter, just chained to the hooks in the bed to keep from becoming projectiles!
Old Jan 26, 2007 | 10:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
Why?
Ice or water it still weighs the same. The straps are designed to hold it down either way.
Old Jan 26, 2007 | 11:24 AM
bc56845's Avatar
bc56845
well for one it might bust the bladder when it expanded from freezing and two if you want to drain it and take it out of the truck you can't if it's frozen.
Old Jan 26, 2007 | 01:08 PM
chiefgianni's Avatar
chiefgianni
I use 2 used backhoe's front blades cut to the width of the box, side by side flat. Its thin and heavy, only about 3/4" thick, starpped to the edge hooks. I place them between wheel wells and tailgate.Does not take any space, when putting in boxes, or atv, no need to remove them. I painted them so wont rust, plus a have a bed cover. I guess any steel plate would do a good job. Ask your used metal yard , they'll calculate the weight according to the size you want for you. Make sure they are help down properly.
Old Jan 26, 2007 | 01:13 PM
ejsmass2's Avatar
ejsmass2
Plastic Continers from HOme Depot
I bought the tube sand from home depot and also got a $10 plastic tote from them to put it in. With a board in the grooves of the bedliner it all stays in place.
Old Jan 26, 2007 | 01:46 PM
redford's Avatar
redford
No, the bladder is designed to allow for the water to freeze and thaw.
No need to take it out, it's also designed to sit UNDER your load.
If it's frozen, you still need it.
Old Jan 26, 2007 | 01:55 PM
bc56845's Avatar
bc56845
I haul stuff in my truck(scrap metal, trannies, rock etc.) that i wouldn't put on top of any rubber bladder, no matter how thick it is, especially if it cost 140$
Old Jan 26, 2007 | 10:43 PM
Musicman250's Avatar
Musicman250
The great thing about carring around bags of traction sand for weight is that if you get really stuck on the ice or snow, you can bust open a couple of bags and throw it under the tires for traction.
Try doing that with a 500lb ice cube!
Old Jan 27, 2007 | 05:37 AM
scraprat's Avatar
scraprat
Top Answer: 5
4x8x1/2" diamond plate fit perfect.And a 5 gal. container filled with wood ash. Through a little by the tires and away you go.
Old Jan 27, 2007 | 09:31 AM
  #28
99f350sd's Avatar
99f350sd
1000 lbs is the minimum I would carry. Any less than that doesn't seem to do much esp with a plow on the front..Be carefull of plastic tubs they slide on bedliners make sure you tie them down.
Dick
Old Jan 27, 2007 | 11:48 AM
  #29
PHWLEE's Avatar
PHWLEE
I use the sand bags myself. Seems to work out nicely and I can take them out easily and or add more. With the added plus of having them in case I need the sand for traction.
Old Jan 27, 2007 | 11:51 AM
  #30
mrxlh's Avatar
mrxlh
The neatest idea I ever saw for weight was used truck intertubes with ah hose clamp on each end filled with sand. They are the pervect width to lay over the wheelwells and take very little to secure. As stated before if you need some sand for traction on ice or frozen snow, undo one of the clamps and viola as much sand as you need. They will not break or leak either like a traditional sand bag.
