My controller seems to be wide open or off. I have the seven pin connector, how can I test the modulation myself? I have a testlight and a voltmeter I just need a little instruction.
(Voltage modulation) Is that not the correct term for it? I want to know if my gain control is working as it should. I don't know the brand name of the brake controller but that shouldn't be a factor.I need to know what pin to measure voltage from and what that voltage should be.
It's fairly simple. Put the plus lead on your multimeter on the brake pin on the connector, minus lead goes to ground (we are at the back of the truck). Brake appliance is simply by an increase in voltage. It will start off at around 2 volts and increase as more braking is applied up to 12 volts. It sounds like you might need a new controller.
Joe
So when I turn the gain **** it should vary the voltage, right? The way you worded it it sounded like the harder I mash the brake pedal the higher the voltage. Sorry, new to the electric brake thing.
With the new Ford controller, it is true that the harder you push the more the controller puts out. It actually reads the pressure from a sensor on the the master brake cylinder.
Get a helper, and while you've got your VOM hooked up at the rear, have him adjust the gain while sliding the manual control lever slowly; the higher the gain, the quicker your VOM should climb to 12vdc when the lever is pushed. If you've got 12vdc no matter what the gain/lever positions are, you've got a bad controller.
Sorry about the confusion. Your controller should have a manual engage slide on it. Start sliding it like you are engaging the brakes. The further you slide it the more voltage you should see at the back of the truck. And yes, it is easier with 2 people.
Joe
I don't see why he couldn't test that at the pigtail harness in the cab, just has to probe the backside of the connection. Would make it easier than having a second person.
I tested it last night. I connected my pos lead to the electric brake pin, neg lead to ground. I moved the level ****, gain **** and the lever in front. Ignition on and off, brakes mashed and not. It had 12 volts no matter what I did.
Steve
Read the above carefully if you do NOT have the Ford OEM Controller on your vehicle. From the sounds of it, you have some brand aftermarket controller bolted to your under dash. You WILL see 12 volts at all times on that type controller (when you hit the brakes or slide the control arm over). The only thing you will change with the modulator adjustment is the attack time of that 12 volts. This is adjustable so that you can adjust for the time it takes for the trailer brakes to come on . The other adjustment control will probably adjust for max voltage to the trailer brakes so you don't skid the trailer tires. Like a light trailer needs less voltage than a big, heavy trailer.
If you have the OEM Ford controller, dependent on year of vehicle, you may not even be able to test as up to mid-year 2005 or so, it was required to have over 5 MPH speed to activate the controller. IE - when the door locks lock, the brake controller becomes active.
I agree that if you DO need a new controller, to buy the Prodigy. Camping World has a pretty good price.
I have a tekonsha controller. (not a prodigy) I do have 12 volts to the pin at all times. It seems like the brakes would be engaged all the time with that voltage there. Am I looking at this wrong? Maybe I have the wrong pin. I'm going by the wiring diagram on the connector cover, it could be wrong. I'll check the other pins tonight.
