weird engine noise
Old Nov 15, 2006 | 10:08 AM
EXPLORER GUY's Avatar
EXPLORER GUY
weird engine noise
I have an 02 explorer,when the weather is warm the engine makes a swoooshing sound,it sounded like a slipping fan belt.It only happens when it's about to change gears.It is more cooler temp now and I can hardly hear it.Ford said that it is coming from inside the engine they will have to go in,they don't have a clue what it is.Anyone had this happen before?
Old Nov 16, 2006 | 10:15 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I've had a lot of these with the fan pulley causing the noise... apparently a few were manufactured slightly wrong causing the belt to glaze.
Old Nov 17, 2006 | 06:00 AM
marragtop's Avatar
marragtop
Can you briefly test it with the belt off to eliminate the pulleys as the cause?
Old Nov 20, 2006 | 10:35 AM
EXPLORER GUY
Angry
OK I took the belt off and drove it up the street same noise,I guess I am sol.Ford said MAYBE it is the timing chain,it will cost about $1200 cdn to fit it.
Explorer Freak
Feb 15, 2011 07:26 PM
Nand12
44
Sep 20, 2004 02:15 AM
twm1974
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 10, 2004 07:14 PM
