HELP!!!!electrical problems in the '75
Old Aug 15, 2006 | 09:49 PM
obey_your_master's Avatar
obey_your_master
Help!!!!! I have a 1975 F-250 4x4 highboy with a 390/C6 combo. It's a great truck as long as it starts. That is where the problem lies. Somebody accidently reversed the polarity when they were changing out the battery (seriously, it wasn't me!). And now the truck does NOTHING!!! I changed out the selenoid, relay, and installed a new battery and it still does nothing. Do I still need to change out the voltage regulator? This truck also contains a lot of Camper/Trailer Special parts but the truck does not have the aux. battery at all. I hope there is nothing seriously FUBAR with the electrical. Any help would be great. Thanks!
Matt
Old Aug 15, 2006 | 10:13 PM
1975Ford's Avatar
1975Ford
Check the fusible links from the starter relay (aka starter solenoid) to the alternator, Some times they will burn out when the battery cables are crossed polarity. Peel back the electrical tape with a sharp razor just grazing the tape. Inspect the fusible links and the solder connection.
Here a link on fusible link https://www.ford-trucks.com/user_gal...=94670&width=0
https://www.ford-trucks.com/user_gal...=94673&width=0
https://www.ford-trucks.com/user_gal...=94674&width=0
https://www.ford-trucks.com/user_gal...=94672&width=0
_____________
-buck-
1976 F150 4x4
1975 F150 4x4
1975 F250 4x4
1978 F150 4x2
Old Aug 16, 2006 | 05:14 PM
1975Ford's Avatar
1975Ford
Also check for any burnt or frayed electrical wires around the battery, alternator, voltage regulator and starter solenoid. Solder all new electrical wires, do not use the crimp on connector, they will corrode and come loose over time.
buck
Old Aug 16, 2006 | 07:08 PM
Mil1ion's Avatar
Mil1ion
I also suspect the fusible links in the main harness to the cab as well.
From the starter SOLENOID or relay ,trace the wiring harness wrapped in tape to just behind the engine head.
In there are the fusible links that power the fuse box and circuitry.
I suspect the reverse polarity melted them clean through.
Andershoberg
Aug 11, 2014 02:26 PM
jjw4413
Apr 6, 2012 09:43 AM
conrad55
19
Jul 18, 2009 02:58 AM
strick88
3.8 & 4.2L V6
65
Nov 22, 2003 09:08 AM
Matt
Jul 13, 1999 07:30 AM
