Lower a 64'
Old Nov 14, 2006 | 11:13 PM
inlandsurf's Avatar
inlandsurf
Question Lower a 64'
Just got a 64, and I want to lower it. It has 4 corner leafs, does any one make a kit, or can I take out a leaf? Any suggestions would be great.
Old Nov 15, 2006 | 07:25 AM
jowilker's Avatar
jowilker
inlandsurf, Welcome to FTE the nations #1 ol Ford tech support site and the 61-66 forum.
One of our contributers will be along shortly with the perfect answer for you.
John
Old Nov 15, 2006 | 03:52 PM
BobbyFord's Avatar
BobbyFord
This is my answer for the front...
http://www.roadsters.com/axles/
For the rear you could C-section the frame and relocate the diff to the top of the leaf spring. Several companies off a kit for this.
Old Nov 16, 2006 | 07:52 PM
jwtimme's Avatar
jwtimme
you can use a drop axil and flip the rear are the two cheapest ways to acomlish a lower. But how much do you want to lower the truck, do you want it in the weeds or just a mild drop. A front end swap is the way to go for a big drop. I used a volare donnor and cut out the solid axil, then did the flip on the rear end. I have not placed the body back on the frame but If my calculations are correct I got about 6 inches of drop in the front.
Old Nov 16, 2006 | 10:19 PM
gangstakr's Avatar
gangstakr
You can view my 64 lowered longbed in my gallery. Tell me if thats what your looking for. Volare front c-notch rear. She sits as low as I need her to.
