I want to replace the bolts on my water pump(93' 5.8) and was wondering if there is anyplace that sells the correct bolts as a package. I know I can probably get them from Fastenal but would rather not have to measure all the bolts and try to get there after work before they close.
Thanks,
Kurt
Yeah, I don't want to pay that much, plus I'm still on a personal boycott of my local dealer since they jacked up my Cougar by the floor pan instead of the correct jacking point.
For the ones I broke I used 5/16 allthread, flat washers and nuts. A little heat really helps removing old ones. The original lasted 170K miles so I may not need to change the water pump again.
My bolts all came out fairly easy but they definately look shabby. I found bolt sets from National Parts Depot for just about everything under the hood except the water pump. I'll look into the complete engine bolt sets. Thanks,
Kurt
