Sponsored by: Auxito
Die-ing after start-up
Old Nov 14, 2006 | 06:32 PM
jjparent's Avatar
jjparent
My 2001 F-150 is not holding an idle after start-up. It normally hovers around 600 RPM, but once started it will die. Not every time. It happens randomly. But once it happens from a dead start, I have to ride the break to get it going. It will then die at a stop light in the same way. It won't hold an idle. It gives no service engine light. I changed the fuel filter, but it still does it. Six months ago I changed the EGR valve.
Old Nov 14, 2006 | 06:42 PM
RangerPilot's Avatar
RangerPilot
Welcome to FTE.
What engine?
On the side of the throttle body should be a metallic cylinder, probably held on with a couple of bolts. Remove it, spray some throttle body cleaner inside of it and drain it out. Let it dry and replace, see if that fixes it. That's the IAC (Idle Air Control valve), it controls your idle when the throttle butterfly valve is fully closed.
Old Nov 14, 2006 | 06:57 PM
jjparent's Avatar
jjparent
Thumbs up
It's the 4.6L and I'll give it a try. Thanks
Old Nov 14, 2006 | 07:56 PM
Gevans17's Avatar
Gevans17
IACV is my guess. Mine did same thing.
Old Nov 15, 2006 | 03:43 PM
saundo's Avatar
saundo
My 01' Screw doing same thing. But I have an aftermarket Air-Force one air intake installed similiar to the K&N. I don't even see the IACV would it even be there with the after market air intake installed? And if not what could my problem be?
Old Nov 15, 2006 | 07:31 PM
tchernosky's Avatar
tchernosky
absolutely, it should still be there. When you are looking at the engine from the front of the truck, it should be on the right side of the throttle body on top. It is a silver cylinder with a plug hooked up to it. Your truck would not work at all without it, so it is there.
Old Nov 15, 2006 | 07:55 PM
saundo's Avatar
saundo
Thanks I'll look again
Old Nov 15, 2006 | 11:55 PM
Racerguy's Avatar
Racerguy
Welcome to the forum saundo
Old Nov 28, 2006 | 07:07 PM
furrby's Avatar
furrby
hi, i have been having the same problems with my 01 w/ 4.6L. i have changed the iac with out it helping. do you think it could be the maf or plugs or c.o.p.'s. thanks for any information you can provide.
furrby
Old Nov 28, 2006 | 10:12 PM
saundo's Avatar
saundo
Die-ing after start up
It was my IAC valve causing the problem. My mechanic replaced it after trying to clean first also cleaned the MAF sensor as well. Starts like a champ again!! He charged $200.00, well worth it for the ease of mind now.
Old Dec 2, 2006 | 08:11 AM
husk's Avatar
husk
Same thing happened on mine. I changed the IAC valve and problem gone. Very easy fix for the DIY'er.
