Transfer Case Questions
Old Nov 14, 2006 | 02:29 PM
blockson98's Avatar
blockson98
Does anyone know if the Borg Warner 1345 and Borg Warner 1356 have the same input shaft as far as diameter and spline count? Thanks for any input!
Old Nov 14, 2006 | 06:34 PM
Cheggie's Avatar
Cheggie
They should. I sucessfully mated a 1989 M5R2 with a 1986 BW 1345, no problems at all. Works like a champ. The M5R2 originally had a 1356 hanging off of it. I drive the truck daily. Be forewarned you may end up with a fixed yoke rear output, which won't work with a slip yoke driveshaft. I had a custom shaft made for my 4x4 conversion.
Old Nov 15, 2006 | 04:49 AM
RTM's Avatar
RTM
I think the broncos tend to have the fixed rear yoke and the F series have the slip yoke.
Old Nov 15, 2006 | 08:29 AM
blockson98's Avatar
blockson98
My 1345 has a fixed yoke. I am changing out the c-6 for a zf 5 speed from a 90 f350. just wanted to make sure the 1345 would spline in.
Old Mar 3, 2007 | 11:55 AM
clunker86's Avatar
clunker86
what oil do you use in a 1345 bg transfer case 86 model
Old Mar 3, 2007 | 03:31 PM
RTM's Avatar
RTM
All the ford t-cases from full size trucks have a 31 spline input.
ClatonK
Oct 31, 2005 09:17 PM
pnose
Offroad & 4x4
Jan 11, 2004 01:52 PM
Silver Bronco
Dec 14, 2003 01:51 PM
