Waste gate
Old Nov 13, 2006 | 10:34 PM
GLAMIS's Avatar
GLAMIS
Waste gate
Why don't the 6.0's have a waste gate?
Old Nov 13, 2006 | 10:54 PM
fireman_19's Avatar
fireman_19
I've been wondering this myself.
Old Nov 13, 2006 | 11:07 PM
6L PWR's Avatar
6L PWR
Because of the VGT turbo. It can control the amount of boost with the variable vanes. Wastegates are for turbos that can't vary their vanes. There has to be a way to limit the boost.
Old Nov 14, 2006 | 03:46 PM
gryf250's Avatar
gryf250
would be cool if it had a wastegate
Old Nov 14, 2006 | 05:48 PM
booker250's Avatar
booker250
Why?
Old Nov 14, 2006 | 06:29 PM
tjheavychevy's Avatar
tjheavychevy
there is some kind of boost valve.I can hear it letting of excess boost if you floor it then let off the throttle real fast.
Old Nov 14, 2006 | 06:39 PM
npccpartsman's Avatar
npccpartsman
That's turbo backpressure coming back through the intake--it's also known as a turbo fart. There is lots of discussion on this issue and is caused by the lack of a wastegate.
Old Nov 14, 2006 | 06:53 PM
tjheavychevy
Thats what they are calling a turbo fart? Got it.Thanks. There is a aftermarket turbo controler that you can put on these trucks but what would be the use?
Old Nov 14, 2006 | 06:56 PM
npccpartsman
What kind of turbo controller are you refering to??? "JakeBrake" controller or a cooldown controller on shutdown. A "Jakebrake" controller could cause you turbo damage or other issues. The VGT turbo is NOT designed to operated this way.
Old Nov 14, 2006 | 07:26 PM
GLAMIS's Avatar
GLAMIS
How does a VGT turbo control the amount of boost? Isn't it the more exhaust the more boost? With a waste gate wouldn't it eliminate over boosting? Iv'e heard of these turbo's making over 33 lbs.
Old Nov 14, 2006 | 07:42 PM
npccpartsman
VGT=variable gate turbo. There are vanes inside the turbo that open and close as controlled by the computer. They effectively change the inner housing size of the turbine (exhaust) side of the turbo to change the boost pressure.
http://dan.prxy.org/Truck/6L_bible_h.../Page_036.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_035.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_034.html
I hope these links work--they should answer lots of your questions about how the VGT turbo works
Old Nov 14, 2006 | 07:43 PM
6L PWR's Avatar
6L PWR
It manages boost by opening or closing its vanes. Thus, Variable Vane. Overboosting comes from the vanes sticking open. Carbon build up and rust can cause the vanes to stick. They are capable of producing over 42 lbs of boost, but the 6.0L can't handle that stock.
On Edit: Thanks Npccpartsman. We must've been tping at the same time, but I was too lazy to look up the bible references. lol
Old Nov 14, 2006 | 07:44 PM
mrxlh's Avatar
mrxlh
Because it is able to make the wheel positive or neutral in pitch, turbos are highly ineffiecient outside of set parameters, meaning small changes make very large differences in compression ratio, this is what the thinking outside the box was, by putting a VGT turbo on, we won't have to have a wastegate, the turbo will able to control the boost right at the compressor wheel. Eliminating the need for an actuator to control the wastegate an decrease turbo lag and shorten the ammount of time to turbo is at or overboosting the system.
Old Nov 14, 2006 | 08:00 PM
npccpartsman
LOL--6L PWR just happened to have it open looking at fuel system parts so it was an easy post.
Yes, Ryan, I wish they'd get the tech folder back up too. It has to be a huge job for the responsible party just because of all the knowledge that has been gathered there over the years. The advances of technology don't let us gap plugs at .35 and points at .12 anymore.........dang those were the good old days
Old Nov 15, 2006 | 07:00 AM
tigertank's Avatar
tigertank
He Said "turbo Fart" Hehehehehehe!!!
