Help!!!!! (cold starting issue)
Old Nov 13, 2006 | 06:35 PM
clutch21's Avatar
clutch21
Question Help!!!!!
I drive a 2000 F250 crew cab 4x4 with the 7.3. My truck will not start in the morning unless pluged in the night before. This problem began in the summer when it was warm during the night. I have changed the glow plug relay but nothing changed. How can the glow plugs be checked without removing them? My manual says there are 2 fuses, one for each glow plug bank, in the glow plug wiring harness but I can't locate them. Any help would be appreciated.
Thanks,
Josh
Old Nov 13, 2006 | 08:16 PM
ReAX's Avatar
ReAX
So the motor turns over, but doesn't start unless you have the block heater on over night?
Fast start glow plug system
The glow plug system consists of:
² eight glow plugs
² the glow plug relay
² engine oil temperature (EOT) sensor
² barometric pressure (BARO) sensor
The glow plug system is electronically controlled by the PCM. The PCM
energizes the glow plugs immediately after the ignition is placed in the
ON position, then determines how long the glow plugs will be on
according to the EOT and BARO sensors. The required time for the glow
plugs to be energized decreases as the engine oil temperature and
barometric pressure increase.
The relay could of failed. However you are getting this far?
3. Turn the key to the ON position.
When the WAIT TO START light
goes off, turn the key to START.
(For Canadian vehicles, the daytime
running lamps will be on if the
parking brake is not applied and the key is turned to ON.)
4. When the engine starts, release the key. The glow plugs will continue
to be activated for up to two minutes. If the engine is not started before
the activation ceases, the glow plug system must be reset by turning the
ignition key to OFF.
Leaving the ignition key ON for over two minutes without starting may
make starting difficult because the glow plugs will cease activation.
Reset the system by turning the ignition key to OFF and then back to
ON again.
That's all the info I could find.
Old Nov 13, 2006 | 11:30 PM
togie's Avatar
togie
Not 100% put if you test glow plugs to ground with ohm meter they should read 1-2 ohms if they are ok
Hopefully someone with more knowledge will give you a 100% answer
Old Nov 13, 2006 | 11:51 PM
Help I M Stuck's Avatar
Help I M Stuck
you said you changed the glow plug relay..did you change the glow plugs?
Old Nov 14, 2006 | 06:00 PM
clutch21's Avatar
clutch21
I have not changed the glow plugs. I wanted to check them without removing the valve covers. Everything appears to be funtioning. The wait to start light comes on and goes off. Longer if cold and shorter after driving and warming up just like it should. Someone mentioned using an ohm meter to check the plugs, where do you conect the positive side to check.
Thanks again,
Josh
Old Nov 14, 2006 | 06:09 PM
ryaneverk2's Avatar
ryaneverk2
Thread moved to 7.3L PSD section. Also added "cold starting issue" so folks have a bit more to go by when glancing down the list than "help!!!"
Old Nov 14, 2006 | 06:17 PM
Uzumati's Avatar
Uzumati
here is the pinout for the valve cover gasket connector
G G I I C I I G G
G= Glowplug
I= Injector +
C= Injector -
Check resistance between "G" and use the engine block for ground a good glow plug will read between 0.1 and 2.0 ohms
Old Nov 15, 2006 | 05:15 PM
clutch21's Avatar
clutch21
Thanks.
I will try to check them tomorrow!!
Josh
