Dramatic Mileage Decrease 02
Any ideas on why like needing new air filter <st1:city w:st="on"><st1 ="">NAPA</st1></st1:city> mod or needing Oil change which I plan to do. <o =""></o>
<o =""></o>
BTW the new CPS worked like a charm and this 7.3 is the cats meow<o =""></o><o =""></o>
Good to be hone
Thanks in advance
<st1:state w:st="on"><st1 ="">Nevada</st1> </st1:state>Max<o =""></o>
02 CC dually 4x4<o =""></o>
If your maintenance is up to date, then track your mileage over a longer period of time to determine if you really do have problems.
One last thing, are you hand calculating mileage, or just reading from the overhead console?
i would recommend a complete service of the engine. change the oil, air and fuel filter. change the oil and have it analyzed (blackstone labs is a great option). and get your diesel only from a place that does alot of business if you can.
if your in constant dusty conditions, then i would recommend a AIS filter or do what i do with my kwik6637 filter, wrap it in ladies nylons, (old off roaders trick keeps the leaves and big things off the filter) as a filter pre-wrap.
after all this has been done do as Pocket suggests, keep a log and compute your mileage by hand and stay away from the overhead lie-o-meter.
hope this helps a bit. let us know that you do and if anything helps.
It was a 7000 mile trip but it was just the last 300 miles I noticed it. I use the ladies hose over the NAPA filter. I did a complete service 8 weeks ago with filters, oil even tranny before leaving. I use diesel kleen.
I'll blow out the filter change the oil and see if she goes back up. We do have head wind out here in the great basin and a front was coming through.
Thanks
Nevada Max
