map line
Old Nov 12, 2006 | 07:08 PM
357fhp's Avatar
357fhp
map line
Hey amiller
What's map line? What color?
Thanks again
357fhp
Old Nov 12, 2006 | 07:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Can it be only Amiller? I know the answer. The MAP line is a black hose about 1/4" in diameter. It runs from the front of the compressor manifold in the center, to the passenger side behind the HVAC stuff up on a little bracket, where the MAP sensor is. It measures the boost pressure. I'll dig up a pic here.
In this pic you can see it closeup of where it terminates at the manifold. It's the black hose that ends at the far right, bottomish of the pic. I have (in that pic) a X-shaped relief valve which i have no more.
http://img.photobucket.com/albums/v3...t/DSCF2569.jpg
And in this pic you can see the other end. I moved the X farther away from the boost tap where i had it before, and the sensor is just to the right of it, in the center of the pic. It has a little different hose routing in this pic from a stock one.
http://img.photobucket.com/albums/v3...t/DSCF2779.jpg
Old Nov 12, 2006 | 07:21 PM
Uzumati's Avatar
Uzumati
It is in a black loom it runs from the base of the Y (center of engine behind fuel filter) to the MAP sensor(passenger side on top of the exterior A/C System.
Edit: I need to type faster
