1980 spark problem
Old Nov 12, 2006 | 06:26 PM
1980f150's Avatar
1980f150
1980 spark problem
question , i have a 1980 302 starts up fine ....but if you shut it off ,then it doesnt have any spark..... i changed the module already , what else could be wrong ? if you let it sit and cool completly it will restart
Old Nov 12, 2006 | 08:23 PM
Piffery1's Avatar
Piffery1
Could be the pickup coil unit inside the distributor.
Old Nov 20, 2006 | 03:46 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Could also be the ignition coil.
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 22, 2006 | 03:05 AM
Chiefrider007's Avatar
Chiefrider007
This might sound crazy but after going through and changing my ignition system, and I mean all of it, I found that the starter solenoid was bad and causing the same problem that you are having. Get a good one and make sure your cables are all clean on both ends and give a look at the fuzeable links while you are at it. I mean clean the contacts that bolt to the solenoid.
Old Nov 22, 2006 | 09:52 PM
Black Ford XLT's Avatar
Black Ford XLT
Right chief, also a undersized battery can cause problems with heat(undersized in the class of battery) seen this a few times Good luck TR
Old Nov 26, 2006 | 07:54 PM
1980f150's Avatar
1980f150
thanks for all the tips ..... i forgot to mention i have changed the starter .... new cables all over ..new selonoid , brand new battery its a project truck that i am rebuilding ....forgot about the coil ...and the pickup inside distributor ....will try those as time and funds permit
Old Dec 2, 2006 | 06:27 AM
Chiefrider007
I had changed my solenoid with two or three, even one new one, still no fire. Went to Napa and got a heavy duty one and fired right up. Just because it's new doesn't mean it's good. If your getting lower than normal voltage at the coil, spark to all cylinders and seems like it should be good fire, chances are it's the problem. I spent three weeks fooling around before I figured it out. Do the voltage/ohm checks for your control module and voltage regulator and you'll be able to tell.
Dflynn926
13
Aug 13, 2015 08:04 AM
Alex Knatchbell
May 26, 2015 09:39 PM
80fordf1504x4
34
May 6, 2015 06:38 PM
Wayne Roberson
Aug 17, 2014 11:26 PM
Lady Sutton
Jan 3, 2013 02:59 PM
