Need help with a cab leak
Old Mar 14, 2008 | 10:07 PM
bryana2639's Avatar
bryana2639
Originally Posted by TNT
Did anyone figure out a source of the leak? Having the same problem.
I removed the plastic intake air grille and found the leak was around the plastic grommets that the grille screws thread into. I put lotsa silicone around those grommets and fixed the leak.
Bryana
Old Mar 15, 2008 | 12:58 AM
TNT's Avatar
TNT
[QUOTE=bryana2639]I removed the plastic intake air grille and found the leak was around the plastic grommets that the grille screws thread into. I put lotsa silicone around those grommets and fixed the leak.
Good suggestion! Thanks!
Old Mar 15, 2008 | 04:17 PM
Mike's 77's Avatar
Mike's 77
It could be the seal around the widshield. I had that problem after I got the truck and hed the seal replaced. however, it still leaked down the inside in the gap between the dash and inside panel. I found that if the windshield isn't lined up just right it will leak. I had it resealed and the second time they got it right. So there could be the possibility that that's what could be causing the water leak.
Old Mar 22, 2008 | 04:53 PM
premo1's Avatar
premo1
my 1978 has a similar problem, the winshield was replaced but nothing changed, it rains my floor is wet, does anybody know where the vent intake (that thing between the hood and windshield) drains? it seems to me that is a possible thing to consider
Old Mar 22, 2008 | 05:08 PM
76f350spercamprspeal's Avatar
My truck doesnt leak
Old Mar 22, 2008 | 10:54 PM
Mike's 77's Avatar
Mike's 77
Was the windshield lined up right? Cuz on my truck the water runs down the inside of the "A" post and down the side to the floor.
SolusUmbra
1983 - 2012 Ranger & B-Series
Mar 13, 2015 11:35 AM
beartracks
Dec 23, 2014 01:56 PM
MageBeowulf
Dec 30, 2011 01:58 PM
bigrigfixer
Sep 16, 2010 01:09 AM
