2002 Explorer Rear Ac Clicking
Old Nov 11, 2006 | 04:07 PM
dtfrench's Avatar
dtfrench
Does anyone have any idea what the clicking sound is that I am hearing from the rear ac/heater in my 2002 explorer. If you do and know a fix I would love to make an attempt.
Old Nov 11, 2006 | 05:31 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
What kind of clicking sound? does it just click once when you turn it on? or is it a constant click, click, click, click...?
Old Nov 11, 2006 | 05:52 PM
pbjohns's Avatar
pbjohns
MazdaRangerGuyInSTL Don't know what kind of clicking sound dtfrench has, but mine is the constant click, click, click..., any ideas?
Old Nov 15, 2006 | 12:08 AM
Mountaineerfixer's Avatar
Mountaineerfixer
Rear Ac Actuator
It is your rear ac/air intake acutuator. I have had 2 replaced under warranty. It is located on the driver side in the rear of the truck, under the internal hatch switch. Follow the noise to an air inlet. A very comman problem.
Good Luck
Old Nov 15, 2006 | 09:26 AM
pbjohns's Avatar
pbjohns
Thanks, do you know if a do it yourself fix is out, I'm retired,and still like to try and fix my own wheels.
Old Dec 22, 2006 | 10:30 AM
edward r's Avatar
edward r
did you get this fixed ?? did you do it yourself ?
Old Dec 23, 2006 | 12:01 PM
pbjohns's Avatar
pbjohns
Not yet, X-mas, $, In the way right now.
Old Jan 5, 2007 | 08:47 PM
bigsam's Avatar
bigsam
My fix to rear air noise
From what I have been told it its a pretty expensive repair. Refridgerant has to be evacuated and recharged. It is the Blend door that is clicking. Mine started clicking after the warranty expired. I only use the Cold air in the back, so while in the cold position I unplugged the motor. No power...No clicking, though I now only have cold air in the back.
2003 4.0 XLT 4wd
Old Jan 6, 2007 | 07:56 AM
pbjohns's Avatar
pbjohns
Mine is clicking all of the time. Took out the fuse, until I get around to fixing it. Just the bride and myself, no real push, would just like to have everything working.
