Disable DRL?
Old Nov 11, 2006 | 01:06 PM
Smokefan420's Avatar
Smokefan420
Disable DRL?
Is it easy to disable the Daytime Running Lights on a '06 F150?
If so How?
Old Nov 11, 2006 | 01:13 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
what if you leave the headlight switch in the manual or off position?
Old Nov 11, 2006 | 01:30 PM
Smokefan420
No, the DRLs are on with the ignition regardless of switch position. I remember that on my '03 there was a plug behind the bumper near the foglight.
Old Nov 11, 2006 | 01:50 PM
wildcard30's Avatar
wildcard30
There are no DRL on the F-150 in the US. You'll need to ask your canadian friends. You might also want to put that info in your next message. Many people do not look at your location info.
Old Nov 11, 2006 | 02:39 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
why do you want to turn them off? I wish my truck had them. It's just one more safety feature that's nice to have.
Old Nov 11, 2006 | 03:53 PM
RobInAB's Avatar
RobInAB
I find them a PITA. At least in my KIA, when the e brake is on, the DRL will turn off. Not the case with my truck and it gets annoying sitting in the parking lot at A&W with my lights on all the time.
Old Nov 14, 2006 | 05:52 PM
Smokefan420
I don't think they are necessary when the vehicle is equipped with automatic headlights.
I was just a matter of removing one stand alone relay.
Old Nov 14, 2006 | 09:23 PM
Chris1450's Avatar
Chris1450
first off, the years long studies thanks to our canadian friends have shown DRL's don't cut down on accidents. Second, I would check with your canadian law enforcement to see if the mounties would have a problem with them not on... third, there should be a spot on your under hood power panel for a relay for DRL's. If you insist on having them, you could get the relay and put it in. I know on my focus there is a spot for DRL relay shown in the owners manual, and an empty spot there under my hood.
Old Nov 14, 2006 | 09:39 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the reason I want them is because my AUTO light switch is not as sensitive as I want it to be. It rains alot where I live and it'll be nearly dark out and the AUTO thing still won't turn the lights on.
Combine that with a white truck in the gloom, and I'm almost invisible
Old Nov 14, 2006 | 09:42 PM
Chris1450's Avatar
Chris1450
I feel your pain tylus... I am in your neck of the woods lol
Smokefan420
My auto lights come on as soon as the sun goes behind a cloud.
Old Nov 14, 2006 | 10:55 PM
Hollywood2005's Avatar
Hollywood2005
If I understand you properly all you have to do is remove a stand alone relay to de activate the Driving lights???
If so where is this relay located??
When removed do the automatic lights still work properly?
Old Nov 14, 2006 | 11:02 PM
Smokefan420
The relay is located on the inside of the left fender under the hood, which relay to pull depends on if you have 4x4 or not. My owner's manual listed as R201. Make sure you pull the relay that is listed as DRL only, as there are 3 different relays that list DRL(the other 2 relays also operate other features)
Auto headlights still function after relay is removed.
Old Nov 14, 2006 | 11:09 PM
Hollywood2005
thanks, I will try it out this weekend. I always hate ideling in a parking lot waiting with the lights on. It wouldn't be so bad if they would turn off like they did in the older Fords with the Parking Brake.
Old Nov 14, 2006 | 11:23 PM
fordman0171's Avatar
fordman0171
The worst thing about DRL's is that it makes the vehicle look like a GM product, and it always seems that one of them is burned out.
