Low Vaccum
Old Nov 11, 2006 | 08:40 AM
DOUBLEF222's Avatar
DOUBLEF222
Low Vaccum
How Can I Boost My Vac. I Did A Vac. Test And It Only Pulls 6lbs At 800 Rps. I Have An 89 F-150 4x4 302 C-6. The Moter Is A Roller Motor With Flat Top Pistons, Heads Are Ported And Polished With A 320 Duration 512 Lift Cam. It Runs Great But Not Enough Vac. For The Brakes. Any Suggestions?
Old Nov 11, 2006 | 11:28 AM
surewhynot's Avatar
surewhynot
I'm not sure how you could boost your vacume, but a reserve tank might help. You could go to a hydroboost setup for your brakes.
