windshield wipers?
Old Nov 10, 2006 | 11:10 PM
fe8u's Avatar
fe8u
windshield wipers?
I have a 2001 sportrac with goofy wipers.
one day all positions will work, then only high speed the next few weeks, then to all positions again.
were to start looking? switch at colum? elsewhere?
Help. thanks
Old Nov 11, 2006 | 05:30 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Remove the steering column covers.. remove the two bolts that hold on the multifunction (wiper/turn signal) switch.. pull the switch back and make sure all the contacts in the connectors are fully seated in place. You might try calling your dealership with your VIN number, as I think I remember some kind of recall on these awhile back.
Old Nov 11, 2006 | 11:09 PM
fe8u's Avatar
fe8u
I did check the wires, would these trucks, suv's have a resistor for the motor like the older trucks?
Old Nov 12, 2006 | 02:43 PM
MazdaRangerGuyInSTL
You might also check all the connections at the body control module... all the resistors, etc are build into that
