7 days @ shop and still won't start
Well I have been having a problem with my 01 power stroke, It will not start.
The truck will just sit there and turn, but will not fire. Work done to date is 2 new batterys, slionid, starter, glow plug relay, fuel filter, heater relay in manifold, removal of securty system-remote starter. It has been at the shop for 7 days and I can't keep it there much longer. Any one have any ideas before I make the shop tow it to the dealer.
Thanks in advance
Pat
Thanks in advance
Pat
Thanks in advance
Pat
Thanks in advance
Pat
on
if it ran great b4 it started this... id say CPS as well..its a very common problem..i know 99 and 2000 the tack doesnt work while its cranking over when cps go's out..im not sure about the 01 though..sorry.. maybe some one will be here soon to tell you if 01 falls in the same..but a cps is what id try 1rst..
i wouldnt get one from ford dealer..go to a IH dealer and get one much cheaper..e-bay even cheaper but will take a couple days..
Originally Posted by amiller93
I just went back and looked at your earlier post, Have they ever checked the HP oil system? or IDM power relay or IDM or PCM and all of the fuses and relays under the dash and hood After the no key spinning starter episode.
Pat
Watch that shop close, it sound like they are shotgunning parts rather than diagnostic tests
Thanks
Pat
Originally Posted by Muktown
maybe your uvc harness have come disconnected or broke so your no power is getting to your injectors or glow plugs. does it smoke when you turn it over?
Thanks
Pat
on
I cant remember from your earlier thread but can you hear the fuel pump come on when you turn the key?
Thanks
pat
