Sponsored by: Auxito
Rear End
Old Nov 9, 2006 | 10:54 PM
z71f150guy's Avatar
z71f150guy
Rear End
i have a 1999 f150 5.4L 330 and i dont kno anything about the rear end and i need to kno the axle spline count and the ring diameter and the gear ratio because i plan on getting posi so if anyone knows please let me kno thanks
Old Nov 9, 2006 | 11:25 PM
paul812's Avatar
paul812
welcome to the forum...you can post the rear axle code from the VIN # plate on the door , or door jam, plus you can crawl under there and get the numbers off the metal plate that bolted to the pumpkin cover. You should have the 9.75 ring gear. Post what you find and someone can decifer the codes, for your ratio, and tell you the # of splines. paul....
