1978 - 1996 Big Bronco
bronco stalled
Old Nov 9, 2006 | 09:01 PM
bronkid's Avatar
bronkid
bronco stalled
Today I was leaving school and had just got to a stop sign and my truck(wich had been running fine all day)up and stalled.I was at the top of a hill pointing downward when it happened,could this have had something to do with the occurance? could the feul have ran to a part of the tank where it became inaccessable? has anyone else expearanced this? p.s. it is an 89 bronco W/a 351w and EFI.
Old Nov 9, 2006 | 09:46 PM
chrono4's Avatar
chrono4
how much gas was in it? did it run fine afterwards or what?
Old Nov 11, 2006 | 04:39 PM
bronkid's Avatar
bronkid
yeah,it ran fine afterwards but today it it wouldn't start.I had to crank the engine for a couple of minutes just to get it to fire.usually all I have to do is touch the key and it starts right up. this time it was on a level surface.as for gas I should have at least 5 gal.
Old Nov 11, 2006 | 04:43 PM
chrono4's Avatar
chrono4
well, have you pulled the codes on it? www.fordfuelinjection.com to pull them
Old Nov 11, 2006 | 04:46 PM
bronkid's Avatar
bronkid
not yet,Il keep that site in mind
Old Nov 13, 2006 | 09:22 AM
Kemicalburns's Avatar
Kemicalburns
that site will show you how to pull codes. codes will tell you whats wrong. with out codes you will be wasting money sensors and stuff that may be fine. when was it tuned up last with new plugs,wires,cap and rotor? might need a new fuel filter. do you hear the fuel pump come on when you turn the key on?
Old Nov 13, 2006 | 06:07 PM
bronkid's Avatar
bronkid
yes I hear the pump kick on, I'm not shure of the last time it was tuned because I just baught the truck in august but I will look through the recepts of the previous owner and probably have it tuned up w\new plugs this weekend.I don't know what happened but now it seems to be running fine
Old Nov 13, 2006 | 10:58 PM
dragonas964x4's Avatar
dragonas964x4
sounds to me like a fuel pump issue, i think there are 2 pumps on those trucks one in the tank and one along the framerail (near the door) and if one quits on ya it may cause it to stall.
Not sure but just a thought, may want to check them both to see if they are working right.
