What is this knock?
Old Nov 9, 2006 | 07:47 PM
rdw516's Avatar
rdw516
Question What is this knock?
Puhleeze offer some insight on this "new" knock.
Just recently when old blackie has been sitting for a day or two, it knocks for a second or two on startup then quits and sounds/runs fine. A mechanic friend of mine said it is a rod bearing slapping a bit until the oil pressure builds up. He advised that if this is all its doing.....run it.
Anybody else had this happen before?
Old Nov 9, 2006 | 08:00 PM
hoxiii's Avatar
hoxiii
It's incredibly common on 300-6's, but it's not a rod bearing slapping. It's a lifter pumping up. It doesn't necessarily hurt the motor, but if you don't like hearing it go and buy an actual Motorcraft oil filter for your truck. When you get it, look down in there and make sure there's a little (typically red) disc in there.
This disc is an anti-drainback valve, it keeps oil up in the motor overnight to prevent dry starts.
Justin
Old Nov 9, 2006 | 08:06 PM
rdw516's Avatar
rdw516
Thanks, The motor has new Crane lifters in it. They were put in this past May when I replaced the Cam. Should they be loosing pressure?
Old Nov 9, 2006 | 08:28 PM
compaddict's Avatar
compaddict
Ticks or Knocks?
Vince
Old Nov 9, 2006 | 08:52 PM
rdw516's Avatar
rdw516
Knocks....no ticks such as the rockers
Old Nov 9, 2006 | 09:02 PM
compaddict's Avatar
compaddict
Knocks are bad and can very quickly turn into an engine failure. After making sure it's internal... I would fix it by whatever means suits you best. Like new engine or rebuild.
Vince
Old Nov 9, 2006 | 09:04 PM
rdw516's Avatar
rdw516
Thats what I am afraid of....Think it could wait until spring? Money is tight right now.....
Old Nov 9, 2006 | 09:41 PM
hoxiii's Avatar
hoxiii
Well, is it a really fast knock (as in the speed of the crank) or a slower knock (about 1/2 the speed of the crank)?
If it's a fast knock is it a high pitched knock or more of a low pitched knack knack knack? If it's really fast it could be at the crank, but most knocks at the crank show up at other times besides startup. Like light rod knocks (high pitched knock) tend to show up on deceleration while main knocks (low pitched knack, sounds like it's coming from deep deep inside the motor) tend to show up under load.
BUT, the fact that it's on startup after it has set a day or so suggests that it's a lifter that has bled down completely. A really dry one can make a knock, but it's a knock that verges on sounding like a tick and is also typically accompanied by a tick.
IMO, for the $3.50 a motorcraft oil filter costs and the $1.50 a quart of oil costs, it's a cheap way to figure out if all it is is a bled down lifter or something you should actually be worrying about.
Justin
Old Nov 10, 2006 | 09:44 AM
jas88's Avatar
jas88
Depends on how loud it is. It's probably a rod bearing, like your friend says, but if it is not real loud, let it go until it is. When you can tell is if you change your oil, or let the truck sit for several days, and then when you start it up it sounds like someone hitting the oil pan with a hammer before it quiets down, THEN it is time to get new rod and main bearings.
Old Nov 12, 2006 | 02:57 PM
emmabiguns's Avatar
emmabiguns
my 1996 4.9 did that shortly after i changed the oil.It did it all of a sudden no matter if it was warm or not. I bought another new Fram oil filter stuck it on and no knock or anything.
