3.8L performance notes
Old Nov 9, 2006 | 06:42 PM
Greywolf's Avatar
Greywolf
I'm told that the 3.8 of choice is the factory supercharged one that was used in Thunderbirds. The reason is that the internals are forged in that version.
I also hear that the crank out of a 4.2L is ideal for a four inch stroke - I'd appreciate any confirmation on that.
The info in this thread WILL be used for a serious build, but before I even start I want to finalize all plans and strategies on this engine. It isn't going to be done twice...
Old Nov 10, 2006 | 06:37 PM
Greywolf's Avatar
Greywolf
Update: As of this afternoon I have some used wheels folks actively looking for the stuff on this shopping list -
Stock 4.2 V6 (latemodel F150) Crank
Thunderbird V6 3.8 engine or whole car, with a blower.
5 or more speed manual tranny that will bolt up to it.
Old Nov 10, 2006 | 07:00 PM
RacinNdrummin's Avatar
RacinNdrummin
The ford 3.8 has got to be one of the most Garbage engines ford has ever produced. Why do you want to do the conversion? Why not supercharge a 5.0 and put it in there? I can understand if you want to be unique, but there is better choices to be unique with than a 3.8/4.2.
Old Nov 10, 2006 | 07:02 PM
RacinNdrummin
I just reread this and I sound like an A**. I didnt mean it in that way, Just in a ponderous way.
Old Nov 10, 2006 | 07:29 PM
Greywolf's Avatar
Greywolf
Alloy heads, small cast iron casting (the block), hyper possibles once the BS stuff is rectified...
The whole idea is to "RIGHT SIZE" the power plant, and then see how far I can go with it...
"Thinking Outside of the Box"
Tom Moranis is right - there is a LOT that can be done with these engines in a small vehicle format.
PS: No offence taken. I have opinions too...
(In case you had not noticed - he says gleefully)
Old Nov 10, 2006 | 11:38 PM
RangerPilot's Avatar
RangerPilot
Could the stock 4.2L crank take it? Just wondering. Depending on the amount of boost you are running, could put a good bit of stress on the crank.
Old Nov 11, 2006 | 06:13 AM
wendell borror's Avatar
wendell borror
The 3.8 has a noted problem with head gaskets, since your doing a build, I'm sure you will have this problem corrected. Super six motorsports has a lot of hipo parts for the 3.8, they know how to squeeze some power out of them, you may want to check out thier site, good luck on your build.
Old Nov 11, 2006 | 08:28 AM
RangerPilot
I saw somewhere on FTE that the 3.8 that was supercharged had a better head gasket. Not saying it shouldn't be replaced, as it most definetly should, but at least you know the 3.8 SC's got something decent to work with.
Old Nov 11, 2006 | 09:31 AM
Greywolf's Avatar
Greywolf
Since I plan on a complete tear-down (to make sure of everything) and machine work - the block itself will be cut for brass O-rings. NOT the heads. Cast iron will hold the o-ring grooves better than aluminum.
Aaron-71
32
Aug 26, 2011 10:30 PM
Dariand1
3.8 & 4.2L V6
Aug 20, 2006 09:04 PM
dmkf15079
3.8 & 4.2L V6
Nov 17, 2005 08:43 AM
squeals99
General Automotive Discussion
Oct 19, 2005 01:02 PM
unreal105
3.8 & 4.2L V6
56
Nov 22, 2003 04:33 PM
