I've been averaging between 12 to 14 in the city (Denver)
Went to Rocky Mt. National Park over 4th of July, 5 passengers, two dogs full load,
four wheel drive for 6miles, 2miles in 4-low, round trip average 18.9
Just got my2000 X 100k miles used V10 4.30 gears 4x4. 12-14 Hwy,10-12 City,+/- 8 towing 5500 lbs tractor and Pulling toy hauler 10k lbs or better @ 65 and get 6-6,5 mpg
Or more precisely...Your driveshaft spins 3.73 times for each revolution of the tire. Higher numbers means your engine spins faster so more torque is put to the ground sooner in a road speed/RPM range.
3.73s will cause the einge to spin slower than the optional 4.30s.
Open Differential (non-limited slip) means you have no locking device or anti-slip device or traction aid device (whatever you want to refer to it as) to aid in either transferring power to the wheel that ain't slipping or "locking" the two wheels together in those low traction situations.
With an Open Diff, power is sent to both wheels and both wheels apply power to the gound (contrary to popular myth) until one loses traction. Then all the power gets sent to that wheel making you STUCK.
