B code Spring swap help needed
Old Nov 9, 2006 | 10:10 AM
rush2112's Avatar
rush2112
I have an 01 Ex 4x4 limited V10 that I just purchased V codes for the front and B codes for the rear. The shop that is putting them on just called and said that the B codes were a 5 leaf setup and I have a 7 leaf setup on now. They say that if I change to the new B codes I will loose some of the stiffness for towing. I'm wondering since I am the second owner if someone has already changed out the rears to something else or are the 7 leaf packs standard. Please help.
Old Nov 9, 2006 | 11:19 AM
TowRig's Avatar
TowRig
You have the stock springs. The 7 leaf spring is standard equipment on 4X4 Excursions. The 7th leaf is actually an anti-windup leaf that just runs forward from the axle.
While it is true you will lose some initial stiffness with the B's, the overall capacity of the B's is higher. I think the person installing your springs is assuming that more leafs equals more capacity, which is not always the case.
Old Nov 9, 2006 | 11:27 AM
rush2112's Avatar
rush2112
Will the rear end be lower since there is 2 less leaf's or will the additional load capacity prevent it from sitting lower?
Old Nov 9, 2006 | 11:34 AM
TowRig's Avatar
TowRig
I installed F's, not B's, so I can't speak from first hand experience. But most that have installed the B's experience about a 1/2" increase in vehicle height. You'll probably see about 1 3/4" increase in the front from the V's.
Old Nov 9, 2006 | 02:01 PM
Stewart_H's Avatar
Stewart_H
Rush, I just answered your PM, but I see you already posted up a thread! Excellent!
I can't answer the height question, because I added a 3.5" tapered block to the rear, swapping out the OEM 2" block, when I did my spring upgrade.
Stewart
Old Nov 9, 2006 | 02:14 PM
rush2112's Avatar
rush2112
Well, I just got back from the shop and they weren't able to do the front springs saying that they would have to take the bumper and radiator apart to get to the front bolts. They didn't want to spend the time so now I'm headed to an off road shop. I should have done this in the first place.
Old Nov 9, 2006 | 02:18 PM
Stewart_H's Avatar
Stewart_H
Yep, the bumper needs to come off, but the radiator stays put. All you need to do is remove the lower support on each side and you can remove the front spring bolt.
Stewart
Old Nov 9, 2006 | 02:51 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Here are pic's of the blocks that people have been installing for 4in in the super dutys. I'll be glad to sell you some if you think these will work.
Ed
Old Nov 10, 2006 | 01:07 PM
rush2112's Avatar
rush2112
WOW, what a difference in ride. I agree with others that have done this upgrade when they say" I should have done this long ago". It took the front end up 2" on Passenger front, 2 1/2" in driver front, and 1 1/2" in both rears. All wells measure within 1/8th of an inch from each other. I now have the ride I have been looking for. Now, are there any taller tires that I can get that will fit on the stock rims? I have 305/70/16's now. Thanks.
Old Nov 10, 2006 | 08:56 PM
Stewart_H's Avatar
Stewart_H
Aint it cool?! I swear, it's like a whole new vehicle the way the Ex rides after the spring swap.
+1. I'm thinking about getting some 16x8 rims and I too wonder how much tire will fit under the truck now.
Stewart
Old Jan 19, 2011 | 08:18 PM
01EX's Avatar
01EX
subscribing
carl2591
Jun 14, 2015 06:03 AM
BeachEx
Jan 23, 2014 03:24 PM
CrowneVic
Jun 13, 2013 08:00 PM
Krisx125
15
Sep 8, 2012 11:33 PM
the ponz
May 4, 2011 04:56 PM
