Buy a bolt about 2" long about the same diameter of the caliper mount hole. Put the bolt in the caliper mount hole with a nut on the backside and tighten bolt. Loosen rotate rotor 180 degrees and tighten it again and it will pop off. Just my rotors last month.
This method is awesome. I used it in the past also.
