Sponsored by: Real Truck
backup lights not working
Old Nov 8, 2006 | 09:01 PM
kblazk's Avatar
kblazk
I have a 2000 F550 and up until a week ago my backup lights worked. I am just wondering if there is a plug or something that is common for this to happen and I could start there before I start tracing back the wires.
Old Nov 9, 2006 | 12:14 AM
Bigfront's Avatar
Bigfront
Perhaps your neutral safety switch is out of adjustment. Its located on the side of the transmission and may have spun a bit and is not aligning with the contacts when the gear selector is in the reverse position...Also, have you checked your fuses? Good Luck...
Old Nov 9, 2006 | 06:45 AM
PHWLEE's Avatar
PHWLEE
Not to be sarcastic, but maybe check the bulbs themselves, though both going out at the same time is less likely.
Old Nov 9, 2006 | 06:56 AM
kblazk's Avatar
kblazk
Never thought to check the fuse, the trans is automatic if that makes a difference.
Old Nov 11, 2006 | 04:19 PM
kblazk's Avatar
kblazk
no fuses blown and lights are not burnt out
M-S-G
Aug 18, 2016 06:06 AM
black & blue 78/9
Apr 7, 2016 06:35 PM
mvedepo
6.7L Power Stroke Diesel
Sep 23, 2011 07:18 PM
jd-tom
Mar 27, 2011 07:45 AM
trevorwithf-350
Apr 21, 2007 09:19 PM
