4.6 vs 5.4
Old Nov 8, 2006 | 08:47 PM
Lacawac's Avatar
Lacawac
4.6 vs 5.4
I'm looking into purchasing a 2000 Expedition XLT for work . The truck is in mint condition, but has the 4.6 engine instead of the 5.4. My concern is in its long term use, not so much speed. All my other trucks have all had the 5.4 engine, so I do have my concerns about the 4.6. Should I pass this truck up and keep looking?
Old Nov 8, 2006 | 09:04 PM
Mr.Novice's Avatar
Mr.Novice
Having only driven the 5.4, you will most likely be less than impressed with the power of the 4.6. However, I own the 4.6 and it will tow a boat like a sunufagun and the longetivity of the 4.6 is without a doubt a winner.
Maintenance is key with these trucks - Just make sure you're not buying somebody's neglected ride and you'll be in good shape.
Old Nov 9, 2006 | 12:10 AM
Wolfman2405's Avatar
Wolfman2405
I recently purchased a 1999 Expedition. In my hunt I test drove both 5.4 and 4.6 models. I have to say that I was not very happy with the 4.6. I had to press the gas pretty good to get up and going. The 5.4(the one I finally purchased) has plenty of power for such a large vehicle. I drove two 4.6's one with well over 130k miles and one less than 100k. I guess it depends on how much power you need or like, in my case I don't really "need" the 5.4 but I like it much better than the 4.6. Just my opinion though
Old Nov 9, 2006 | 05:23 AM
dynajim's Avatar
dynajim
I have a 98 with he 4.6 and my neighbor has a 5.4. Can't tell any difference when towing the same trailer with either truck. There is only a 15 hp difference.
Old Nov 9, 2006 | 08:30 AM
shov76's Avatar
shov76
Drove em both. My parents 00 4.6 and my 03 5.4. Both motors are very dependable (the 4.6 doesn't even spit out plugs ) and you can expect a long life. As stated earlier, maint. is the key. If it's mint and what you're looking for I'd go for it. Towing is a different story. Althought the 4.6 will tow, the 5.4 has more ummph.
Specs below
2000 Ford Expedition Technical Information <TABLE cellSpacing=0 cellPadding=7 width=600 border=0><TBODY><TR align=left bgColor=#ffff99><TD>Vehicle Type</TD><TD align=middle colSpan=2>Full-size Sport Utility Vehicle</TD></TR><TR align=left><TD bgColor=#cccccc>Engine</TD><TD bgColor=#cccccc>4.6</TD><TD bgColor=#cccccc>5.4</TD></TR><TR vAlign=top align=left><TD>Displacement / Type</TD><TD>4.6L SEFI V-8</TD><TD>5.4L SEFI V-8</TD></TR><TR vAlign=top align=left><TD>Compression Ratio</TD><TD>9.0:1</TD><TD>9.0:1</TD></TR><TR vAlign=top align=left><TD>Horsepower @ rpm</TD><TD>215 @ 4400</TD><TD>260 @ 4500</TD></TR><TR vAlign=top align=left><TD>Torque (ft-lbs) @ rpm</TD><TD>290 @ 3250</TD><TD>345 @ 2300</TD></TR><TR vAlign=top align=left><TD>Transmission (standard)</TD><TD>4 speed automatic with OD</TD><TD>4 speed automatic with OD</TD></TR><TR vAlign=top align=left><TD>Final Drive Ratio</TD><TD>2.64:1</TD><TD>2.64:1</TD></TR></TBODY></TABLE>
Old Nov 9, 2006 | 08:32 AM
shov76's Avatar
shov76
Here's a link about the 2000 Expy
http://media.ford.com/products/press...421&make_id=92
Old Nov 9, 2006 | 11:12 AM
Lacawac's Avatar
Lacawac
Thanks for the feedback-- still deciding...
Old Nov 15, 2006 | 09:07 PM
2000Expy's Avatar
2000Expy
I have the 4.6. It's fine for in most cases. If you're going to pull something dual-axle and heavy, you might want the 5.4. If you drive in the Rocky Mountains, you want the 5.4. Otherwise, why take the gas mileage hit? I've had zero engine or transmission problems.
Old Nov 15, 2006 | 09:23 PM
amm888's Avatar
amm888
not trying to be argumentative, but i've heard that the difference in MPG is rather negligible between the 5.4 and 4.6. i've owned two 5.4s and test driven (though never owned) several 4.6s. personally i would not buy a 4.6 because i really like the added feeling of power in the 5.4, but the 4.6 is more than adequate for everyday driving.
al
Old Nov 16, 2006 | 08:57 AM
peter57's Avatar
peter57
I own the 4.6 and have been very happy. It has less torque than the 5.4 and I don't think the mpg is much better than the 5.4 either. I get an average of 13mpg consistently. Two big benefits for me is that it is not coil over plug design and that the heads don't eject plugs. Both of these issues are significant and common problems for the 5.4's. Both can also be expensive to repair.
Old Nov 16, 2006 | 11:16 AM
wrenchturner's Avatar
wrenchturner
there is no replacement for displacement.
Old Nov 16, 2006 | 05:16 PM
1owner's Avatar
1owner
I, too, bought a used expy. I chose the 5.4 because of the higher torque it makes. I use this vehicle mostly for camping trips. It gets 16 mpg @ 70 mph pulling 2200#'s of pop up trailer.
Old Nov 18, 2006 | 11:52 PM
eviljarv's Avatar
eviljarv
i have both and i like the mpg of the 4.6 for regular driving but if you are planning on towing i would definetly go with the 5.4, it has like 60 ft-lbs more torque at 1k rpms lower, just my 2 cents
