Different pulley setup?
Old Nov 8, 2006 | 08:23 PM
tonpartain's Avatar
tonpartain
Admittedly, I've not seen many of these trucks. However, I was poking around a salvage yard yesterday and saw a different setup with respect to the pulleys:
Four grooves on the crank, two on the alternator, two on the water pump, and one each on the a/c compressor and power steering pump.
Anyone ever seen such a setup?
Old Nov 9, 2006 | 04:35 AM
jowilker's Avatar
jowilker
Hate to have to ask, but would you like to leave a couple clues, as to what you may have been looking at or is this a trick question?
John
Old Nov 9, 2006 | 04:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Yes...truck (car?) had a dual belt alternator.
Old Nov 9, 2006 | 08:56 AM
tonpartain's Avatar
tonpartain
It was a '74 ford pickup truck, not sure what size engine.
Old Nov 9, 2006 | 12:25 PM
jowilker's Avatar
jowilker
Boy you are a barrel of fun, is it a V4, V6 or I-8 engine?
John
Old Nov 9, 2006 | 08:56 PM
FordBoypete's Avatar
FordBoypete
T-Bird FEs & F-600 with the FT engines are belted that way and I think some of the 429/ 460s running 95amp Alts are too.
Alt + W-Pump + balancer use a double set up. The P/S & A/C Comp use singles all in dedicated grooves.
FBp
Old Nov 9, 2006 | 10:33 PM
tonpartain's Avatar
tonpartain
Sorry, John. Not trying to be cute. The engine is a v8. The belts ran as follows:
The belts on the two pulleys on the alternator ran to two of the pulleys on the crank.
The belt on the water pump ran to a third pulley on the crank.
The fourth belt ran around the a/c compressor, idler/tension pulley, and power steering pump.
Old Nov 10, 2006 | 06:09 AM
jowilker's Avatar
jowilker
Hey man, I aint trying to bust your chops either. As the mod I try to guide things along for the greater good of the forum. We can not see the truck like yourself, and having a good explaination helps us provide the answers that posters desire.
Like Pete, I had a good idea of your setup, but wanted you to verify.
John
KsCop
Apr 3, 2014 05:33 PM
cbfomoco
Nov 22, 2005 02:28 PM
flyflinger
Oct 16, 2005 08:58 PM
flagator
Dec 7, 2004 04:54 AM
e william
Aug 7, 2004 03:10 PM
