Sponsored by: Real Truck
Boost Tube?
Old Nov 8, 2006 | 03:21 PM
John Schneider's Avatar
John Schneider
Boost Tube?
Not able to search the forums which seems odd. New here as you can tell. I am just curious what kind of gains can be achieved from the simple little mods like the Boost Tube and Dual Relief Valve? They seem so easy to do and are cheap. Is there a noticeable difference in performance? Sorry if this is a dumb question.
Old Nov 8, 2006 | 06:29 PM
clux's Avatar
clux
You may see a little benefit from the boost tube and increased manifold pressure that comes with it, and the releif vaulve will let you go to higher boost levels than stock without defuling the engine. But you won't really be able to benefit from the increased boost unless you are running programming that is injecting more fuel than the stock program.
I'll bet you get asked about the Dukes of Hazzard all the time.
