Too Lean @ 12 mpg?
Old Nov 8, 2006 | 02:23 PM
irulewhenshesnothome's Avatar
Red face Too Lean @ 12 mpg?
I am getting a 171 code (too lean bank 1) and a 174 code(too lean bank 2) on my 1996 f150 4.9, 5sp with 110000 miles on it. I have done fuel filter, air ,oil, plugs ,wires,cap and rotor.
I am getting 12 miles per gallon.
Sometimes the idle rolls up and down.
PLEASE HELP
Old Nov 8, 2006 | 02:45 PM
andym's Avatar
andym
If you haven't ever changed your O2 sensors, this would be a good time to do it. It will most likely both your mileage problem and clear those two codes.
Old Nov 8, 2006 | 02:48 PM
I will check that out. I think my truck has two of them.
Old Nov 8, 2006 | 02:49 PM
Thanks, Just replace them both and hope for the best?
Old Nov 8, 2006 | 05:17 PM
EPNCSU2006's Avatar
EPNCSU2006
Also try cleaning the heating elements in the mass air meter. The thin wires can get coated with dirt over time, causing the sensor to indicate less air than is actually going into the engine causing a lean condition. Clean the heated wires very carefully and very gently with a q-tip and some rubbing alcohol.
Old Nov 8, 2006 | 08:15 PM
sbowling79's Avatar
sbowling79
do you know how to pull the codes without a scan tool I would like to check mine for any codes
Old Nov 8, 2006 | 08:37 PM
EPNCSU2006's Avatar
EPNCSU2006
It depends on what year. The 96 is OBD-II which requires a code reader. If you have an older truck, you can pull them yourself. Run a google search for "eec-iv self test" and follow the instructions. Most of those pages will also have a helpful illustration of which wires to jumper.
Old Nov 8, 2006 | 09:36 PM
I have a scan tool for OBD2 . It seems to push me in the right direction.......sometimes
Old Nov 9, 2006 | 10:16 PM
Today I replaced the o2 sensors and cleaned the air flow sensor with q-tips and alcohol. I drove 2 drive cycles and the light came back on. Same codes as before(171, 174). I checked ALL the vaccum lines and looked for leaks.
ANY IDEAS ?
Old Nov 10, 2006 | 09:23 AM
Kemicalburns's Avatar
Kemicalburns
did you disconnect the battery for awhile then reconnect and drive?
Old Nov 10, 2006 | 02:00 PM
Yes I did and the light stayed out for 30-35 miles.
