55 ford wheel base question
Old Nov 8, 2006 | 09:00 AM
Outnumbered's Avatar
Outnumbered
I bought a ‘55 f100 from a local family. The truck is in pieces and I have nothing to take measurements from. I am thinking about using an ’87 ford mark VII for donor parts. The mark VII has the 302HO with a 4speed ADO trans, 4 wheel disk brakes, and air ride suspension. Can anyone give me the original wheel base measurements for the ’55?
Old Nov 8, 2006 | 09:36 AM
Huntsman's Avatar
Huntsman
Welcome to FTE!
110" stock, front wheels were not centered in the front fender openings in Mr. Ford's design.
Old Nov 8, 2006 | 11:58 AM
Outnumbered
thanks Tom, I am sure I will have more questions in the future, this fourm is a great reasource!
Old Nov 8, 2006 | 06:38 PM
DonMckay's Avatar
DonMckay
I thought they were 114 inch wheel base.
Don
Old Nov 8, 2006 | 07:20 PM
51dueller's Avatar
51dueller
48-52 were 114"
53-56 were 110"
Old Nov 9, 2006 | 03:51 PM
fking1's Avatar
fking1
Don
48 to 52 F1's are 114.
53 to 55 F100's are 110.
Fred
Old Nov 9, 2006 | 05:38 PM
AXracer's Avatar
AXracer
Just to confuse the issue, 53-56 F100, F250 with the 8' express bed had 118" WB.
If changing the suspension many move the front wheels 1- 1 1/2" forwards of the stock position to better center the front wheels as mentioned.
I don't know if the tread width matches the 53-56, but IMHO you DO NOT want to use the air ride suspension, it is nothing but expensive trouble. If you are considering a frame swap, the very best advice I can offer is FORGET IT! Don't even think about it for another minute, or you'll live to regret it. There are far better suspension choices that can be added to the stock frame. Use the donor engine and tranny in the stock frame.
Old Nov 10, 2006 | 05:50 AM
GreatNorthWoods's Avatar
GreatNorthWoods
...And the 48-52 F2s and F3s also had the 8 foot express bed and had a 122 inch wheelbase.
Old Nov 10, 2006 | 06:22 AM
raerjim's Avatar
raerjim
Outnumbered, save yourself trouble all the way around and forget the whole thing. I'll give you 150$ for the truck. HAHA
Old Nov 10, 2006 | 11:41 AM
fergusonicford's Avatar
fergusonicford
newbie here.....fking1 says '53 - '55 = 110" and 51 dueller says '53 - '56 = 110" so can a '53 thru '55 frame be swapped on a '56 ?
Old Nov 10, 2006 | 12:10 PM
Randy Jack's Avatar
Randy Jack
Yes. The frames are essentially identical except the 56 has longer rear springs. But the 56 sheet metal will fit on any 53-55 frame. Just run the rear springs for the frame you are using.
AXracer's Avatar
AXracer
Welcome Furgusonicford!
Yes, the only difference is the 56 springs are a slightly different length, so the springs are not interchangable between years without changing the spring hangers, otherwise they're all the same.
OOPS! Randy beat me to it... gotta get faster fingers!
Old Nov 10, 2006 | 03:02 PM
fking1's Avatar
fking1
Talking
Finally, a straight answer. Why do we always have to confuse things??
Fred
Old Nov 10, 2006 | 03:37 PM
AXracer's Avatar
AXracer
??? There was more than one question, and the first had more than one correct answer.
Some want a simple cut and dry answer, some want a complete answer.
Old Nov 11, 2006 | 07:03 AM
merc546's Avatar
merc546
Well, really the 53/54 rear springs are 48 inches long and the 55/56 rear springs are 52 inches long. I think the difference is the rear spring hangers on the 55/56 were moved rearward the 4 inches.
Chuck
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
07EXPYEL
Jun 7, 2016 11:51 AM
Holehawgg
Dec 1, 2011 01:44 PM
Yahnozha
Jan 9, 2006 11:27 AM
mark_the_redneck
4 Cylinder Engines
Oct 30, 2004 08:07 PM
