1978 - 1996 Big Bronco
90 5.8L Idle Issues
Old Nov 8, 2006 | 02:25 AM
greybullit's Avatar
greybullit
90 5.8L Idle Issues
My 90 bronco with a 5.8L EFI is acting up. At idle the rpms fluctuate pretty derastically. It also will shut off if trying to leave from a parking space or something like that when the engine is using more power for the power steering and stuff. Anyone had an issue like this before?
Old Nov 8, 2006 | 08:27 AM
Kemicalburns's Avatar
Kemicalburns
could be tps, iac or something else. pull the codes and report back. www.fordfuelinjection.com will show you how its easy.
Old Nov 8, 2006 | 09:54 PM
Bimmerboy1989's Avatar
Bimmerboy1989
could be a vacuum leak, test the intake gaskets with carb cleaner. Spray it on the intake gaskets and see if it idles up. If so then you have found your problem.
BURNSTOUGHFORD
Mar 3, 2011 04:29 PM
77150KIDD
Jan 31, 2010 11:44 PM
Loganwildman
Sep 26, 2004 08:19 AM
scootin
Jul 10, 2002 12:38 PM
charlez
Aug 31, 2001 07:55 AM
