fuel injector cleaner
Old Nov 7, 2006 | 09:17 PM
breisr's Avatar
breisr
does this stuff really work? what is involved in replacing the injectors? is it necessary?
Old Nov 7, 2006 | 09:50 PM
frederic's Avatar
frederic
I've not had much luck with "pour in the tank" injector cleaner.
What I end up doing about every 100k or so is taking the injectors off the intake, and put them on a fixture I made, and drive them with a simple pulsing circuit and feed them kerosene for a while, then mineral spirits using a fuel pump. Sounds wonky but it works well.
They are cleanable/reusable as long as the coil works.
Old Nov 7, 2006 | 10:00 PM
Jrock909's Avatar
Jrock909
What is the best way to clean fuel injectors, besides going to a shop and then they run a machine to clean out your fuel injection system...
Old Nov 7, 2006 | 10:37 PM
breisr's Avatar
breisr
not sure, i'm wondering the same thing. i bought some pour n the tank stp and was wondering if it will help or hurt. i'm doing this as preventitive maintenance.
Old Nov 8, 2006 | 10:18 AM
quicklook2's Avatar
quicklook2
run a can of seafoam thru tank. do it when you have less than 1/4 tank of fuel.
Old Nov 8, 2006 | 05:21 PM
cuztom79's Avatar
cuztom79
seafoam? whats that and what is it supposed to do? thanx
Old Nov 8, 2006 | 05:48 PM
quicklook2's Avatar
quicklook2
it is a lot of things, but one of them is fuel injector cleaner.
google seafoam for info.
do search here for seafoam use.
stp additive is a waste of time.
chevron techron is a good additive, gets high ratings.
Old Nov 8, 2006 | 06:24 PM
cuztom79's Avatar
cuztom79
thanx for the info, but why wont this site let me search, says i dont have permission?
Old Nov 8, 2006 | 06:49 PM
quicklook2's Avatar
quicklook2
oh, forgot the search engine is down for repair.
