Dies in reverse when cold
Old Nov 7, 2006 | 06:49 PM
ssanto's Avatar
ssanto
Hi,
I have a 1985 F-150 with a 302 and a Holley 4bbl carb.
The engine starts up very easily when cold. It idles fine and revvs fine. When I put it into reverse, the engine stumbles and dies. I can start it again and it idles fine but dies when I slip it into reverse. Only after I let it idle and warm up for a full minute or so will it not die in reverse. Once its warm everything is OK.
My other truck is a 1997 F-150 with fuel injection. I can start it and immediately put it in reverse and drive. I'm not that familiar with carbureted trucks. Is this something I have to get used to? Or is there something I can adjust to make it better?
What is the minimum amount of time I should have to wait before being able to drive the truck when starting it cold?
The outside temp is around 75 degrees if it makes a difference.
Thanks,
Sal
Old Nov 7, 2006 | 09:46 PM
WA1986F-250's Avatar
WA1986F-250
Does it do this when put in drive as well? It sounds like the choke needs to be adjusted.
Old Nov 7, 2006 | 09:54 PM
ssanto's Avatar
ssanto
Yes... It dies in drive as well. Which way should I adjust the choke? Its a holley electric choke.
Thanks!!
Old Nov 7, 2006 | 11:43 PM
ssanto's Avatar
ssanto
My F-150's EGR isn't working. It never opens. Would this partially explain why the truck dies when I put it into gear if its cold?
Thanks,
Sal
