Need Help On Np435
Old Nov 7, 2006 | 03:57 PM
74 HIGHBOY's Avatar
74 HIGHBOY
Need Help On Np435
i need some help on the np435. i have a 74' f250 with a 390 and div. trans case setup. i started to have a vibration so i check the driveline and found the output shaft on the transmission was wobbling. now i have the long tailshaft housing that mounts to the back of the transmission. is there a bearing in there? or just a seal? or both. is the bearing in the back transmission going to need replacing?? thanks for your replies...
Old Nov 7, 2006 | 04:31 PM
Mil1ion's Avatar
Mil1ion
I don't know the answer to the question but I do know,
FTE has a drivetrain forum for specific questions on drivetrain components.
Old Nov 7, 2006 | 04:43 PM
Franken-Truck's Avatar
Franken-Truck
Fixed yoke? As far as I know, the bearing is a giant ball bearing that sets in the bore of the case itself, and the tail housing to hold it in. Don't think there is anything else back there but a seal
